www.ColoradoClassicBroncos.com - View topic - BC Broncos 23 gal main tank skid plate
It is currently Fri Nov 01, 2024 4:37 am
Reply to topic  [ 20 posts ]
Post BC Broncos 23 gal main tank skid plate
Long shot, but maybe someone has one they want to part with.
Tue Jan 19, 2016 5:38 pm
Post Re: BC Broncos 23 gal main tank skid plate
I just bought one yesterday with a new tank. Damn they're expensive!
Tue Jan 19, 2016 7:20 pm
I'd like to come by and take a look at it.
Tue Jan 19, 2016 7:46 pm
Me too. I'm thinking about making one.
Tue Jan 19, 2016 7:57 pm
I really need one. Have a few dents already
Tue Jan 19, 2016 11:46 pm
I've got a nifty design in mind that will get rid of that dent problem in the future.
Tue Jan 19, 2016 11:56 pm
Are they 1/8" plate? I've got masses of 1/8" plate in my stash and was thinking of building one my self.
Wed Jan 20, 2016 7:26 am
Justin, can your brake bend 1/8 or 3/16 at the width needed? The BC skid is made from 3/16, but 1/8 would be better than nothing. I'll have to measure the width of the tank if you don't have access to one.
Wed Jan 20, 2016 7:37 am
Do it once and use 1/4". That is what I made mine out of. I've hit it a few times and it is scratched but not dented. A couple of the hits would have very likely bent anything thinner.
Wed Jan 20, 2016 7:41 am
Good call, I'll price a sheet of it, it'll only weigh 1000 lbs haha
Wed Jan 20, 2016 8:34 am
I think the last sheet of 1/4" was something like $225. And I couldn't move it by myself. I don't think my brake will do 1/8th, and it definitely won't do 3/16". I think the most my press brake will do is 19" wide. I'm planning to make my tank out of 16g, but to make a cradle with 1/8" sides and a 3/16" bottom that supports the tank from underneath and bolts to the bottom of the frame rail. Two straps over the top of the tank will hold it down. Should be much more secure than anything else out there, and provide plenty of protection.
Wed Jan 20, 2016 9:18 am
1/8" will bend on it's own. However, my old Ranger truggy used an 1/8" belly skid plate with reinforcement ribs to give it bending strength. You could pick the whole truck up by the skid with no deflection. Ribs were spaced about 10" apart, ~3/4" tall.
Wed Jan 20, 2016 10:23 am
I want to be an engineer.
Wed Jan 20, 2016 9:24 pm
I would be in for pieces of that 1/4 plate or whatever is bought and bent. Or I could weld the angles if needed. Ideally something close to the tank for clearance.
Thu Jan 21, 2016 9:23 am
I'll get some pics of my plate tonight as a small idea for you guys. It is on the stock gas tank so it is different but I tucked it in as close to the tank as I could. It is bent to follow the tank and it has 90* reinforcements on the sides and front. Very sturdy.
Thu Jan 21, 2016 11:59 am
Of the BC tanks out there how many are the newer rail mounted variety? It'll be easy to build one with tabs & I agree w/ Crawler, I'd like edges around the circumference
Thu Jan 21, 2016 1:23 pm
Here is my skid. I could have done a better job with it but I've supported the back end of my bronco with it and slammed it on rocks so it serves it's purpose.
Thu Jan 21, 2016 7:51 pm
Thu Jan 21, 2016 10:50 pm
I have the rail mounted version
I also have the BC skid plate and can take dimensions or take it off for templating
Fri Jan 22, 2016 7:03 am
Mine showed up yesterday.
Fri Jan 22, 2016 7:08 am
Users browsing this forum: No registered users and 57 guests
32,739,927 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
