It is currently Fri Nov 01, 2024 4:34 am
[ 29 posts ] |
Steering stuff
Need a drag link, track bar, and stock tie rods for non-inverted Y set up steering linkage. If you're tripping over some parts leftover after a tie rod over conversion, I'll help you get rid of them.
Also need a power steering pump bracket and pump.
Let me know what you've got and what you need for it.
Tue Jan 19, 2016 10:59 pm |
Colorado75bronc
Re: Steering stuff
I've got a Saginaw bracket, no pump
Sent from my SAMSUNG-SM-G890A using Tapatalk
Tue Jan 19, 2016 11:25 pm |
Re: Steering stuff
Tue Jan 19, 2016 11:32 pm |
Re: Steering stuff
Your timing is good, just pulled the sag setup from Bubba Smurf, I should also have the track bar.
Wed Jan 20, 2016 7:04 am |
Re: Steering stuff
I've got a bunch of 351 parts. Including a sag pump and bracket. intake manifolds, carb, duraspark dist and wires and module, timing chain cover, water pump, pulleys, the whole front dress. Only thing not there unless you can convince Corey to give them is the accessory adaptors. Let me know if there is anything you want. I need the space in my garage.
Wed Jan 20, 2016 7:30 am |
TOOLMAN
Re: Steering stuff
I know I have a drag link laying around my shop.
I thought you were trying to get rid of stuff!
Wed Jan 20, 2016 8:19 am |
Re: Steering stuff
Wed Jan 20, 2016 12:21 pm |
Re: Steering stuff
Wed Jan 20, 2016 12:22 pm |
Re: Steering stuff
Wed Jan 20, 2016 1:04 pm |
Re: Steering stuff
Wed Jan 20, 2016 1:47 pm |
Re: Steering stuff
What, you don't need a factory 351w intake that's really, really blue?
Wed Jan 20, 2016 8:43 pm |
Re: Steering stuff
Wed Jan 20, 2016 8:53 pm |
Re: Steering stuff
Wed Jan 20, 2016 9:49 pm |
Steering stuff
Frank- I might have an extra linkage with tie rod and drag link. I'm out of town but I'll check and send a picture on Friday if I do.
Wed Jan 20, 2016 10:03 pm |
Re: Steering stuff
Thu Jan 21, 2016 5:22 am |
Colorado75bronc
Re: Steering stuff
It's a wildhorses bracket, $25
Thu Jan 21, 2016 9:11 am |
Re: Steering stuff
Thu Jan 21, 2016 9:34 am |
Colorado75bronc
Re: Steering stuff
Cool, are you going to be around Friday/tomorrow night around 7-7:30? I may be able to get it and the old free02 over to you in one shot.
Fri Jan 22, 2016 1:47 am |
Re: Steering stuff
Fri Jan 22, 2016 7:21 am |
Colorado75bronc
Re: Steering stuff
Sunday morning work then? And if so any particular time?
Fri Jan 22, 2016 9:47 pm |
Re: Steering stuff
Fri Jan 22, 2016 11:03 pm |
Colorado75bronc
Re: Steering stuff
OK sounds good, I'll call you Sunday morning
Sat Jan 23, 2016 12:55 am |
Re: Steering stuff
Sun Feb 07, 2016 8:07 pm |
Re: Steering stuff
Mon Feb 08, 2016 10:16 am |
Re: Steering stuff
Mon Feb 08, 2016 11:37 am |
Re: Steering stuff
Mon Feb 08, 2016 1:41 pm |
TOOLMAN
Re: Steering stuff
Tue Feb 09, 2016 8:41 am |
Re: Steering stuff
Tue Feb 09, 2016 9:24 am |
TOOLMAN
Re: Steering stuff
Tue Feb 09, 2016 11:02 am |
[ 29 posts ] |
Users browsing this forum: No registered users and 81 guests |
