It is currently Fri Nov 01, 2024 4:38 am
[ 6 posts ] |
Engine block plate
Need an engine block plate for 289-302-351w. This is the large sheet metal piece that goes between the block and an automatic transmission. In case you were unsure.
Thu Feb 11, 2016 11:27 pm |
Re: Engine block plate
You can certainly have mine if you want it, Out of my manual. Surely you could modify it by lying the inspection cover over the bottom and cutting that part off?
Thu Feb 11, 2016 11:37 pm |
Thu Feb 11, 2016 11:56 pm |
I have one. I'd be happy to drop it in USPS or UPS for you tomorrow, if that would work.
Also have a flexplate from my 1995 351.
Fri Feb 12, 2016 12:36 am |
Fri Feb 12, 2016 9:03 am |
Fri Feb 12, 2016 12:52 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 62 guests |
