It is currently Wed May 22, 2024 10:13 pm
66 Wiki
To help with quell my worsening case of 66 OCD, I'm going to try to post/maintain a list of differences between 66 model year and others. There are a lot of "66 only" threads on CB.com, but they all seem incomplete, and repetitive.
I'd like to document the differences with pictures, and if possible the production dates of each oddity. I have accumulated many of these "facts" from threads here, on CB.com, discussions with some enthusiasts, and other web sites. I'll do as best as I can to note where I got the info.
This is just a bullet pointed list I've worked on for the last few hours. I'll be fleshing this out with pics & links if possible. Please feel free to post up additions & adjustments to my info. I'll adjust my list or add pictures or links to try to keep it current.
Sheetmetal
Budd tub- August 1965- October/November 1965 Short a-pillar/kick panel P1020993.JPG
No recess for Ford emblem on floor panel above driver side rocker IMG_20160223_204856.jpg
Passenger side inner fender to firewall brace
Gutter above driver floor pan- behind pedals
Gutters on kick panels behind dash Pics by eaglesnest66 on cb.com Drivers side driver rain gutter.jpeg
Windshield frame Hardware to fold windshield & secure to hood
Grill Eyebrow grill- August 1965-October/November 1965 20160305_110103.jpg
Hood
Hoop mounted to hood to secure windshield when folded down 20160305_110213.jpg
Doors Key hole location above body line- 66-67 models
Latch/striker location -66-67 picture_2540.jpg
Removable window frames- 66 model year
Full wagon top Key lock separate from door handle – 66 Tailgate handle design - 66 P1030001.JPG
Roof bows bolted in -?
Mon Feb 29, 2016 11:24 pm |
Re: 66 Wiki
Interior:
Pony interior option in 'Option Package' in later post
2 defrost ducts, metal duct work Dash pad- straight, no hump on driver side 20160305_110442.jpg
Glass mount 66-67 (also same as 65/66 Galaxie) 67 mirror.jpg 67 mirror2.jpg 66mirror3.JPG
Horn button Horn button & horn ring include “Product of Ford Motorcompany” print 12804000_10205740053126631_1359934389_n.jpg
Pic from Okie4570 on CB.com: 20150730_170555_zpscts3htrs.jpg
Turn signal, shifter, dash controls Fluted knob design 66- 20160305_110631.jpg
T-shift lever, knob & boot – 66 only pic from Okie4570 on CB.com: 20150730_170607_zpsqve3sbfw.jpg
Tall t-case shifter vs Short shifter Short shifter replaced the taller shifter about 12/65 Tall: 20150730_170607_zpsqve3sbfw.jpg
Short: get-attachment-9.aspx.jpeg
T-case shift pattern sticker on dash pic by BroncoFresh75 on cb.com parchement dash.jpg
Interior door panels – gray painted metal only/early 66 panels had only 7 screws to attach to shell, later panels used 9 screws Arm rests- location/style- black only Inside door handle & window crank 66 pic on bigskybroncos.com picture_2540.jpg
Front Bench seat Silver Vein vinyl only- 66 model year Folds forward with no catch Silver plastic hinge covers 20160305_110515.jpg
Front bucket seats –same as 65 Mustang buckets Silver Vein vinyl only- 66 model year Top of back of seat is thinner than later seats No footmans loop Seats fold with no catch Black plastic hinge covers pic from bigskybroncos.com get-attachment-8.aspx.jpeg
Rear bench seat Silver Vein vinyl only – 66-? Small arm rests – black only- 66-67 Pic by wepuckett on CB.com nos 66 rear bench with belts.jpg
Driver’s fresh air box Sheet metal – August 1965 – October/November 1965 P1030214.JPG P1030215.JPG IMG_20160227_132301.jpg
Air box to hood seal & cowl seal IMG_8374.jpg IMG_8375.jpg hood airbox seal.jpg
Speedometer - different font, MPH "tick" marks are outside the number, instead of inside Pic by Okie4570 on CB.com 20150730_170628_zpsminm6t53.jpg
Mon Feb 29, 2016 11:25 pm |
Re: 66 Wiki
Drivetrain, brakes, suspension steering:Brakes Single reservoir master cylinder – 66 20160305_111615.jpg P1030251.JPG Rear drum brakes have no “auto” ratcheting adjustment Carb- 66 only throttle bore size P1030255.JPG Oil bath air cleanerI6 pic on bigskybroncos.com picture_2307 (1).jpg V8 v8oilbath.jpg v8oilbath2.jpg Front axle Brass 90* fitting on fill hole 20160305_110812.jpg P1030253.JPG Full time 4x4 with drive slugs pic by 66Bronco on CB.com 66 full time hubs 66bronco.jpg Lock out hubs – 66-67? P1030216.JPG pic on bigskybroncos.com 66hubcapft.jpg Lock out hub operation sticker on door panel pic by brianstrange on cb.com dana spicer hub sitcker.jpg Warn lock out hubs pic by Broncitis on CB.com DSCN2091.jpg 20160305_111213.jpg Rear axle No fill hole on carrier, fill hole in rear of housing P1030008.JPG 20160305_110900.jpg Driveshafts U-joints/yokes- Borg Warner drive shafts, Dana Spicer 1310 yoke- 66-70 Ujoints- Precision 497 (Mechanics 2.5r to 1310) viewtopic.php?f=5&t=7715Rear shocks Mounted forward of axle Upper shock mount 20160305_111042.jpg Steering linkage Rebuildable drag link end
Re: 66 Wiki
Misc:Option packagesfrom 4 Wheeler article "Custom Equipment Package"- hub caps, chrome bumpers, tail light bezels, horn ring, cigarette lighter, sun visors, arm rests "Pony Edition" interior- parchment dash & door panels & arm rests, parchment front floor mat, Pony Mustang seats Pics from this thread on cb.com: http://classicbroncos.com/forums/showth ... p?t=184584parchement dash.jpg parchement door.jpg pony interior.jpg pony interior2.jpg Rocker stripeimage7.JPG Underside of tubLeft in primer, no body color paint, tubs possibly primer diped pics by eaglenest66 on cb.com primer underbody with overspray.jpeg Fenders/'Bronco' emblem - only uses 4 locator pins, instead of 5. VIN tag location on driver's kick panel- 66-67 No auxiliary tank - 66-67? P1020994.JPG Main tank strap- 66 IMG_3655.jpg IMG_3656.jpg Wheels'Spoke' shape- 66-67 pic from BlueBastard on cb.com 66 wheels.jpg stamped with K/H? pic from elan on cb.com kelsey hayes rims.jpg Hub caps – 66 pics on bigskybroncos.com 66hubcapft.jpg digital_pics_1_453.jpg Skid platepic on bajabronco.com skid.jpg Exterior mirrorsChrome pic by Okie4570 on CB.com DSC00370_zpshvd8rta6.jpg http://www.virginiaclassicmustang.com/6 ... P1921.aspx'Roadster' mirror pic from bigskybroncos.com digital_pics_1_453.jpg 20160305_111536.jpg image7.JPG Fuse panel on firewallWiring66BroncoLightDiag.pdf 66wiring.pdf Washer bag – 66-67 P1020985.JPG Rear brake & turn signals No reverse lights Fender turn signals/reflectors No signals or reflectors on fenders 20150922_180152.jpg Turn signals on grill- smaller, inset into grill, clear lens Head lamp trim ring- no holes to access adjuster screws 20160305_110103.jpg JackP1030394.JPG Jack, handle, lug wrench Jack location- right rear corner of bed, behind rear tire well, with jacking instructions pic on bigskybroncos.com Restorationspg2--element82.jpg Jack handle & lug wrench location- on floor behind driver's seat pic by bigskybroncos.com 66handles.jpg pic by eaglenest66 get-attachment.aspx.jpg Bumpers- straight cut ends, different front & rear bumpers- 66 Spare tire location Bench/bulkhead- mounted to bulkhead behind passenger Buckets/rear seat- mounted to inside of tailgate on passenger side
Mon Feb 29, 2016 11:26 pm |
colby45
Re: 66 Wiki
Wed Mar 02, 2016 9:05 am |
Re: 66 Wiki
Wed Mar 02, 2016 12:57 pm |
colby45
Re: 66 Wiki
I don't recall seeing a sticker for hub use instructions, but it could be there. I've heard dealers often left it up the the buyer to put it on if they wanted. I'll be working on the Bronco tomorrow so I have a list of pictures to take
Fri Mar 04, 2016 1:12 pm |
colby45
Re: 66 Wiki
I'm just going to update parts of Gunni's post that didn't have pictures.
Sheetmetal
Windshield frame Hardware to fold windshield & secure to hood 20160305_110215.jpg
Hood Hoop mounted to hood to secure windshield when folded down 20160305_110213.jpg
Interior:
Turn signal, shifter, dash controls Fluted knob design 66- 20160305_110625.jpg 20160305_110631.jpg
Front Bench seat Silver Vein vinyl only- 66 model year Different back cushion to lower cushion hinge bracket Silver plastic hinge covers 20160305_110515.jpg
Speedometer - different font, MPH "tick" marks are outside the number, instead of inside See above photo
Sun Mar 06, 2016 1:00 am |
colby45
Re: 66 Wiki
b]Drivetrain, brakes, suspension steering:[/b]
Brakes Single reservoir master cylinder – 66 Rear drum brakes have no “auto” ratcheting adjustment 20160305_111615.jpg
Rear Axle No fill hole on carrier, fill hole in rear of housing 20160305_110900.jpg
Rear shocks Mounted forward of axle Upper shock mount 20160305_111042.jpg.
Misc: Option packages from 4 Wheeler article "Custom Equipment Package"- hub caps, chrome bumpers, tail light bezels, horn ring, cigarette lighter, sun visors, arm rests 20160305_110509.jpg 20160305_110127.jpg
Sun Mar 06, 2016 1:14 am |
colby45
Re: 66 Wiki
Front turn signals No signals on fenders Smaller, inset into grill Clear lens 20160305_110103.jpg
Sun Mar 06, 2016 1:17 am |
Re: 66 Wiki
Awesome, thanks! My truck is not super photogenic right now, that helps a lot.
Beautiful visors!
Yours is a U14, right? What were the snaps for?
Sun Mar 06, 2016 10:23 am |
colby45
Re: 66 Wiki
No problem. Anything I can do to help.
Mine is a little rough around the edges too, but the core is there so I'm hoping to remedy that over the next few years.
It is a U14. The snaps were for a cloth bed cover in the back. Not sure where or when those and the light on top were added.
Sun Mar 06, 2016 3:22 pm |
Re: 66 Wiki
Budd tub oddities:
RT9 has a September 66 built 67 with a gutter or drip rail behind the pedals, no indention for the "Ford" emblem under driver seat.
He's going to look his tub over and see if there is any other Budd stuff.
And this October 66 built 67 U13 has Budd looking a-pillars & later? kick panels.
Doesn't look like it has a drip rail, but hard to tell.
This truck was originally exported to Columbia. The owner did not answer when I asked if it has any other Budd features.
Mon Mar 07, 2016 1:13 pm |
jdgary
Re: 66 Wiki
This thread is great!! I'm working on the tear down of my 66 now and was curious about interior colors for when I send it out to paint.
Thanks for the invite Chad!
Mon Mar 14, 2016 9:27 pm |
Re: 66 Wiki
From what I've read, PPG code 32549 should be the correct color for the dash & door panels.
Mon Mar 14, 2016 9:41 pm |
Re: 66 Wiki
Added a few things.
Rain gutters on kick panels behind dash, proper steel wheel, underside of tub was not painted, but left in primer.
Sat Mar 19, 2016 8:00 pm |
Re: 66 Wiki
Added 4th hood, better pic of rim, dana spicer hub & t-case shift pattern stickers, & info on Pony interior package.
Sat Mar 26, 2016 9:22 am |
Re: 66 Wiki
Saw a line of '66s recently and checked out the mirrors. There were 4 different types. 20160416_110240.jpg 20160416_111230.jpg 20160416_110503.jpg 20160416_110614.jpg 20160416_110529.jpg
Tue Apr 19, 2016 11:02 pm |
Re: 66 Wiki
That is exactly what I thought, they were using whatever they had around.
I got pics today of a confirmed August 65 U13 mirror that is different than any I've seen.
Tue Apr 19, 2016 11:22 pm |
casadejohnson
Re: 66 Wiki
This evening I rediscovered another 66 ( and I'm guessing 67,68 ) difference. I was replacing my worn out window tracks this evening and noted that the original rear window track has a flat fork shaped upper attachment point while the later doors without removable window frames have a threaded attachment point. The difference is so that the upper attachment point can be sandwiched in-between the door and the window frame. I forgot to take a photo but I'll try to get one tomorrow. I should have remembered this because I had replaced the track on the other door several years ago and ran into the same issue. I did a little searching and I was unable to find anyone selling the early style rear window track. Looks as though a little welding may be the way to sort this out.
Thu May 05, 2016 12:52 am |
Re: 66 Wiki
Thanks,
Also, the inside door panels are held on with 7 screws, apparently 67's added 2 screws along the top edge. No surprising, as my 66 panel seems to bow away from the door shell, along the top edge, just a little.
I've also heard some talk that the original 66 fuel pump has 10 bolts around the top. Mine has only 8, but I have no clue if its original, or not.
Thu May 05, 2016 7:17 am |
casadejohnson
Re: 66 Wiki
Thu May 05, 2016 10:00 pm |
Re: 66 Wiki
I haven't taken my doors apart, but here is a pic where the 7 screws are visible. I'll take more pics when the doors come apart.
Thu May 05, 2016 10:08 pm |
casadejohnson
Re: 66 Wiki
That door handle is not like mine. I thought that was the 67 style.
Thu May 05, 2016 10:36 pm |
Re: 66 Wiki
I have a 66 handle to replace it. The driver's door is correct, just harder to take pics of right now.
Thu May 05, 2016 10:37 pm |
casadejohnson
Re: 66 Wiki
For reference here are the two styles of window track Sent from my iPhone using Tapatalk
Re: 66 Wiki
Looks like they added the 2 extra screws to the door panel sometime during the 66 model year. All the 66 restos (with doors) on Big Sky Bronco's site have the extra screws. Maybe a Budd thing.
Thu May 05, 2016 11:05 pm |
casadejohnson
Re: 66 Wiki
My door handles Sent from my iPhone using Tapatalk
Thu May 05, 2016 11:10 pm |
casadejohnson
Re: 66 Wiki
66 bronco vacuum fuel pump Sent from my iPhone using Tapatalk
Sat May 07, 2016 4:14 pm |
Re: 66 Wiki
I see what they did there
Sat May 07, 2016 5:30 pm |
