It is currently Sun Nov 24, 2024 3:06 am
Re: 66 'restoration'
Tue Mar 01, 2016 6:24 pm |
Nice score. Has this thing consumed all of your Bronco self? Are you going to get your "other" one running any time soon?
Tue Mar 01, 2016 6:27 pm |
LOL. I'm actually making decent progress on my 74. I should be back running by May or June.
I haven't really done any work on the 66, just reading up on stuff.
Sniped the horn button off a FB page, noticed an early 66 tub in a picture of someone doing some major metal work. I noticed he has some major mods going on, so I send him a message asking if he had any stock parts to sell. The FB Bronco folks aren't too 66 savvy.
99% of everything else came from Don's. Molly's picking up a little more tomorrow. It's been stupid easy.
Tue Mar 01, 2016 6:52 pm |
Tue Mar 01, 2016 9:22 pm |
Tue Mar 01, 2016 9:33 pm |
Tue Mar 01, 2016 9:43 pm |
sykanr0ng
Thu Mar 03, 2016 12:16 am |
You might be right, Coby45 has a bench in his that folds, and you don't get any earlier than his. I doubt mine is a 66 bench. I was all wrong about the tailgate spare tire mount. My tailgate has holes drilled in it that indicates it used to have a spare tire mount. P1020999.JPG https://www.tomsbroncoparts.com/product ... ord-broncoThe rear floor is drilled for rear seats, it would not have been, if it was a bulkhead model. The Buck Tag lists (no one knows exactly what the codes mean, but this seems to be the current opinion) OPCAR=open cargo, no bulkhead BSDP=bucket seat, driver, passenger RS=rear seat LGROOF=full wagon roof MIR=mirror HTR=heater WSW=windshield washer P1020990.JPG The 7 in 798 on the VIN tag indicates front bucket seats as well. P1030043.JPG At this point the plan will be to rebuild it as a bench/bulkhead model. First of all, I really like it this way. Second, I have a bench in beautiful condition that can be run as is, or add a silver vein cover to make it look more authenic. I'll have a set of correct seats, if I want to refinish them & install them, I can. Or if it is ever sold, the next owner could return it to original. I'd have to put some serious money into restoring the seats I have to make them presentable. So building a bench/bulkhead truck will put it back on the road sooner, and less expensively.
Thu Mar 03, 2016 12:37 am |
colby45
I do have one pic of my bench from my build log: It does fold, but it does not slide. Of course, I only have the bench because mine is a half cab, so I can't speak to the front seats that would've been in the regular cab. I do know this bench is original.
Thu Mar 03, 2016 9:30 am |
The 66 buckets I bought have no catch to prevent them from folding & apparently they didn't use a footman's loop to secure the passenger seat to the floor. I guess all that helped lap belts get the reputation as "back breakers".
Thu Mar 03, 2016 12:59 pm |
Aztec77Bronco
Joined: Thu Jul 05, 2012 11:54 am Posts: 119 Images: 0 Location: Just south of Durango
_________________ '77 Sport, 302 HO on it's way to a resurrection! '03 Mercedes CLK 320 Cabriolet (W208 body) '13 Ford F350 Lariat Crew Cab 4wd Power Stroke
Thu Mar 03, 2016 4:13 pm |
Thu Mar 03, 2016 10:36 pm |
rt9
No. I was going to put it back in now that I got a new windshield. Sorry.
Thu Mar 03, 2016 11:02 pm |
I knew it was a long shot. LOL.
Thanks for the pic, now I know what I'm looking for.
Thu Mar 03, 2016 11:09 pm |
1965ish Galaxie mirror head.
Fri Mar 04, 2016 12:51 am |
I'm revealing how far behind in my magazine reading I am but in the December 2015 issue of Four Wheeler there is an article called "Jeep looks at the 1966 Bronco". There could be some valuable information gleaned from this article featuring some original pictures.
The spare mounted to the inside of the tailgate caught my eye. And what appears to be folding bucket seats. I might be able to post pics if needed.
Fri Mar 04, 2016 6:33 am |
I'd love to see any pics you could post.
Thanks
Chad
Fri Mar 04, 2016 8:16 am |
rt9
Fri Mar 04, 2016 8:57 am |
Fri Mar 04, 2016 9:56 am |
Aztec77Bronco
Gunni, I found another thread on cb.com that may help you in some hard to find stuff for your '66 http://classicbroncos.com/forums/showth ... p?t=262712their website & phone are northeastclassicfordparts.com (website is new and just has a mere fraction of the parts we stock! call with needs) 1-610-986-5506 I found a lot of NOS on their site. maybe they have a NOS mirror for you.
Fri Mar 04, 2016 1:59 pm |
Thanks for the links.
Looks like Big Sky Broncos is for sale, as a business, home, shop & land. Hmmmmmm.
Delconic was recommended to me, as he might have a 66 horn ring. I got a set of his door seals for my 74. I'll look through his stuff. Ebay has a couple nice used mirrors in the $40 range. I saw a NOS one sold for $50 recently.
Fri Mar 04, 2016 4:45 pm |
I really don't know if this is of any use...and of course, it seems they uploaded in reverse order.
Sat Mar 05, 2016 1:42 am |
Interesting article, thanks. I just scanned the article, but they mentioned an 'optional' interior that wasn't listed in the sales literature. That is a new one to me.
Sat Mar 05, 2016 10:38 am |
This article lists a "Custom Equipment Package", including chrome bumpers, hub caps, bright taillight bezels, cigarette lighter, horn ring, arm rests, and visors.
I had read about a "bright" package on CB.com, it included the tail light bezels & lighter that my truck is equipped with. My truck never had visors, therefore did not include the "Custom Equipment Package". And throws my assumption about hub caps, chrome bumpers, and horn ring, out the window. LOL
Sat Mar 05, 2016 11:04 am |
Fri Mar 18, 2016 11:19 am |
Interesting, but unfortunately right now, its out of the budget.
Fri Mar 18, 2016 12:15 pm |
Couple more parts pics
65/66 Galaxy mirror very nice condition, a couple small spots on the mirror. Remove the Galaxy hanger, and swap for a similar year truck stem & button pivot and it will be right. P1030286.JPG
Air box to hood seal
I posted a couple early 66 facts to the Wiki. My truck does have the rain gutters behind the dash on the kick panels. Its hard to get good pics.
Also, they didn't paint the bottoms of the early trucks, just left them in primer, with signs of over spray from when the exterior was painted. The bottom of my tub is white/light grey.
Sat Mar 19, 2016 9:06 pm |
I also have confirmation that 66 bench hinge covers were silver, and buckets were black, also that the rear view mirror is the correct one.
Sat Mar 19, 2016 9:30 pm |
Pieces of the puzzle are coming together!
Mon Mar 21, 2016 2:12 am |
Wed Apr 13, 2016 12:06 pm |
