It is currently Sun Sep 22, 2024 1:38 am
pgilbeau
Re: Air Compressor and Tools
Thu Mar 10, 2016 4:49 pm |
how old is the house? Also there should be a main breaker that feeds everything. It would say 100/125/150/200 amps depending on service. If you have a 50 amp breaker marked hot tub but dont have one you may get lucky.
Thu Mar 10, 2016 6:10 pm |
Those two 50 amp breakers would be perfect to run a sub panel off. Mine is run off a pair of 60's and ive had no problems with supply.
Thu Mar 10, 2016 6:19 pm |
pgilbeau
Thu Mar 10, 2016 7:29 pm |
You've got plenty of power to do what ever you want. Find an electrician and have them look at it. It wont be much more expensive to set a sub panel over just a 220 compressor.
Fri Mar 11, 2016 7:33 am |
Aztec77Bronco
Joined: Thu Jul 05, 2012 11:54 am Posts: 119 Images: 0 Location: Just south of Durango
_________________ '77 Sport, 302 HO on it's way to a resurrection! '03 Mercedes CLK 320 Cabriolet (W208 body) '13 Ford F350 Lariat Crew Cab 4wd Power Stroke
Mon Mar 14, 2016 10:35 am |
These look like a decent deal to get a nice reel. Missing the guides but they aren't super required. Yank the hydraulic hose and install your own air hose and you're set.
Mon Mar 14, 2016 11:56 am |
pgilbeau
Looks like the power issue in my garage is going to get resolved, going to get set up for an air compressor and welder, also still doing new lighting. I think I am going to go with the compressor Justin has. Can anyone post some pics of their set up? I am basically re-configuring my work area and looking for ideas. Since I am planning ahead for welding what are some good welders, I would primarily be using it for the Bronco.
Thu Mar 24, 2016 8:39 pm |
I can post up a pic or two. What's the welder budget? If you can spend a grand, there are some awesome options. Also some great ones for less.
Fri Mar 25, 2016 9:06 pm |
My 60 gal IR.
I would recommend a welder 180amps minimum, probably a 210 if you can swing it. Hobart is a good less expensive brand made by Miller (we use a Hobart 230 almost everyday at the bodyshop). Miller & Lincoln are both great brands. Justin has a Thermal Arc, and likes it.
I have an older Century welder 230 amps, its big and loud, but I really like it.
Sat Mar 26, 2016 10:22 pm |
There is a Porter Cable 80 gallon on CL: http://denver.craigslist.org/tls/5509968432.htmlI have the Tweco 211i welder which is pretty much the same as what Justin has. It's a great welder and you can usually find it for less than $1000. You definitely want to go as big as your budget will allow.
Sun Mar 27, 2016 8:42 am |
pgilbeau
Right now I am just getting the electrical done and going to most likely get the Home Depot 60 Gallon compressor. Realistically I am just trying to figure out everything I need to get and what outlets and circuits I should get installed. I don't have a welder budget at the moment, just trying to get ideas/plan for down the road.
Sun Mar 27, 2016 8:50 pm |
The cheapest welder I'd buy is the hobart mvp 210. It's a solid welder, and hobart is owned by miller. With a couple hundred more in budget (money well spent) I'd be looking at the new version of the Miller 211 or the Lincoln 210 Mp that came out recently. I'm generally very happy with my thermal arc 211i as well, but there are fewer places to have it serviced.
Sun Mar 27, 2016 9:02 pm |
