It is currently Fri Nov 22, 2024 10:02 pm
[ 10 posts ] |
New Battery and smoking wires
Bobby73
Okay...newbie here! I installed a new Optima battery and these two connectors started g. Is it the wrong size battery and where do I start trouble shooting the electric. Gracias! Bobby Sent from my iPhone using Tapatalk
Sun Mar 13, 2016 11:50 am |
Re: New Battery and smoking wires
Moved to '4x4 tech'.
Sun Mar 13, 2016 12:39 pm |
You appear to have a wire missing from your starter solenoid. And it looks new. Did you recently replace that as well?
Sun Mar 13, 2016 1:26 pm |
Bobby73
New solenoid and took wire off to look at connectors, but was connect before.
Sun Mar 13, 2016 2:21 pm |
Bobby73
Ran after replacing solenoid and then battery died over winter.
Sun Mar 13, 2016 2:23 pm |
Bobby73
Looks like it was spliced and then silicon caulked?? Sent from my iPhone using Tapatalk
Sun Mar 13, 2016 2:30 pm |
Mon Mar 14, 2016 4:45 pm |
Bobby73
Okay...fixing loose connections and found fusible link was cooked Sent from my iPhone using Tapatalk
Tue Mar 15, 2016 9:08 pm |
Bobby73
Okay...after a bunch of soldered connections and a new solenoid I finally have fixed the problem. Thanks guys.
Sun Mar 27, 2016 9:43 pm |
Thumbs up!
Mon Mar 28, 2016 8:57 am |
[ 10 posts ] |
Users browsing this forum: No registered users and 44 guests |
