www.ColoradoClassicBroncos.com - View topic - Roll bar for half cab ??
It is currently Fri Nov 01, 2024 4:22 am
Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
Post Roll bar for half cab ??
I'm am looking for a roll bar that will fit my half cab. Any ideas ? Thanks
Mon Nov 16, 2015 8:09 am
Post Re: Roll bar for half cab ??
For Inside the 1/2 Cab,
Or for the Bed?
Mon Nov 16, 2015 9:09 am
I have a Stroppe look alike that you could cut the length down on the horizontal arms that I'd give you for $50 bucks.
Mon Nov 16, 2015 9:11 am
Pm sent
Mon Nov 16, 2015 6:00 pm
Cool! It's yours ;)
Mon Nov 16, 2015 9:00 pm
Sweet thanks again
Tue Nov 17, 2015 11:19 am
It's slowly turning into a roll cage.
Was going to use the stroppe roll bar but decided to use it for measurements to fab my own style of roll cage.
It will still be close to looking like the stroppe style but will have a custom look to it.will post more pictures as I go
Tue Mar 08, 2016 9:49 am
You should leave it that height.
Looks like a wake board tower, KC Lights and speakers?
You can call it Your "DON'T Roll over Bar"!!!
Keep up the Good work! Bend-er up and Weld-er up!
Tue Mar 08, 2016 12:31 pm
:Welding: Looking good... popcorn
Tue Mar 08, 2016 1:25 pm
I was able to sneak out for a couple hours last night and I got the last 2 bends in the hoop and cut to the height I wanted it. It was a one man test fit and camera man.
Wed Mar 09, 2016 9:56 am
Since this has become a build thread, I moved it.
Wed Mar 09, 2016 6:13 pm
So I noticed that when trying to get a 90 degree bend I would have to go to 95 because of back flex. So now I've kind of got the hang of it. The bends I did today were right on the money. I've never have done this before but I'm happy with my progress and the look of it.
Sun Mar 13, 2016 7:52 pm
Yep spring back does apply. Couple things to make is easy: figure out where you shoe starts to make bends and mark it. I also use 2) 36" pieces of 1/8" flat bar bolted at one in for a large scale angle finder. Typically I will lay it on top after I bend to confirm angles. Something else to consider, I took a 3" square tube (3" long) and drilled a corner for a peice of all thread, welded a nut inside. I use this for compound bends along with a angle finder. Your gettin it though!!!!!
Sun Mar 13, 2016 10:38 pm
Looks great! If it's there for safety more than appearance, you may want to consider a little triangulation.
Mon Mar 14, 2016 8:23 am
Mon Mar 14, 2016 1:10 pm
I was able to get it all mocked up and bolted down to the bed of the truck. I forgot to think of the tailgate but it shut just fine.
All that I have left is.
1. supports under body to frame
2. Finish welding the seams.
3. Add tire carrier
4. Adding 2 triangles minimum
5. Tabs for lighting
6. Tab for CB antenna
7. Tabs for tie downs
8. Anything else I can think of that I might need
Fri Apr 01, 2016 9:52 pm
Great work, looks Good!
Fri Apr 01, 2016 11:51 pm
Looks good, do you hunt? The wildlife guys run small winches up high in the back of the bed so they can load up game.
Sat Apr 02, 2016 5:51 pm
Sat Apr 02, 2016 7:53 pm
Got some more done today. I got the supports under cut and mocked up along with 1/2 of the spare tire mount. I also got the axle stub shaft cut down for the tire to attach.
It was so much fun cutting the axle shaft. Took me forever.
I'm hoping to have it done with in a few more weeks.
As far as hunting I do and I had a plan for that down the road. Was thinking of making a mount that will attach some how somewhere some way lol. I'm just glad it's going half way smooth.
Sat Apr 02, 2016 9:31 pm
That is a great idea for spare tire mount, I like it.
Mon Apr 04, 2016 6:54 am
Great work!
Spare tire - I'd mount it as low as you can to keep the Center Of Gravity low and below your rear view mirror. I like the idea!
Game hoist - You could always mount a winch low and use a pulley attached to a steel loop on your top bar for height.
Tue Apr 05, 2016 5:58 am
Tue Apr 05, 2016 8:57 am
I kinda figured you were stowing things under it!
Tue Apr 05, 2016 12:13 pm
Nice work! Man, I do love these half cabs!
1974 Bronco, 302, C4
Wed Apr 13, 2016 9:22 pm
I was able to work on it. I got the under supports primed and painted. I also got the other two pieces mocked up and ready to weld. Now all I have is welding grinding and paint. It's getting closer especially when this has been a 4 year project oh (the electrical tape is Custom)
Fri Jun 24, 2016 7:31 am
Looks good Buddy you're on the home stretch.
Fri Jun 24, 2016 10:41 am
Profile WWW
I need to remeber to use tape on my joints. Seems faster than welding. Looking good!
Fri Jun 24, 2016 12:57 pm
Got it finished up and in primer. I'm happy with the end result.
Fri Jul 22, 2016 11:18 pm
Lookin good !
Sat Jul 23, 2016 2:57 am
32,739,338 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
