www.ColoradoClassicBroncos.com - View topic - Looking for a running 302
It is currently Fri Nov 01, 2024 2:28 am
Reply to topic  [ 11 posts ]
Post Looking for a running 302
Looking to pick up a running 302 can be stock will be used for a buddies 50's Willies project.
Let me know if anyone has one they are looking to part with.
Fri Apr 01, 2016 8:45 pm
Post Re: Looking for a running 302
I have one from my 76', running good when pulled but had a vacuum leak. I was going to use it for my 74' project until I pulled the 351 trigger.
$200?
Fri Apr 01, 2016 10:59 pm
I just pulled my 302, It came from a 91 or 92 5.0 mustang gt. It is a builder though and I believe it needs a rebuild. It does have crane lifters on the e7 heads, so someone did some work to it. I would include an msd ignition edlebrock intake.
TJ
F. Scott Fitzgerald
Sat Apr 02, 2016 8:51 pm
Pic.
TJ
F. Scott Fitzgerald
Sat Apr 02, 2016 8:52 pm
Sat Apr 02, 2016 10:38 pm
Sat Apr 02, 2016 10:39 pm
No problem
TJ
F. Scott Fitzgerald
Sun Apr 03, 2016 12:04 am
I have a 302 HO (351 firing order)I was told it ran when I bought the bronco, but the transmission was stolen after a rebuild right before I bought it. I'm doing a power plant swap to either 351 or diesel .
Sent from my SAMSUNG-SM-G870A using Tapatalk
'77 Sport, 302 HO on it's way to a resurrection!
'03 Mercedes CLK 320 Cabriolet (W208 body)
'13 Ford F350 Lariat Crew Cab 4wd Power Stroke
Sun Apr 03, 2016 7:34 am
Landshark, any chance your buddy could use a running 302 that is bolted up to an NP435 and dual Dana 20's? You can come see it all running before I pull it all out .
Tue Apr 19, 2016 6:48 pm
Yes^^^^ and add that cold duck to the red bronco.
Tue Apr 19, 2016 7:02 pm
The Cold Duck is for sale out of the red Bronco.
If you wana check it out, message me your number and we can meet up.
Tue Apr 19, 2016 10:20 pm
Users browsing this forum: Google [Bot] and 69 guests
32,738,429 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
