It is currently Fri Nov 01, 2024 2:28 am
[ 17 posts ] |
Few items I am looking to collect
I will be starting my search this summer for next winter's project. I will be changing the heads on my 351W from the stock heads to some GT40 heads. If you have any you are looking to unload or see some at a junkyard-- let me know. I am in no hurry so will be patient for the 40 not P heads.
I am also in need of a Dana 20 rear output shaft/housing. Would like to carry one as a trail spare. So if you upgraded your rear output shaft and have a stock you are looking to unload, please let me know.
Thank you!
Tue May 10, 2016 6:17 pm |
Re: Few items I am looking to collect
Curious why you don't want the P heads? You may have a slightly easier time finding some cheap and your Hut headers should fit them fine.
Tue May 10, 2016 8:35 pm |
Tue May 10, 2016 8:41 pm |
Fair enough!
Tue May 10, 2016 8:48 pm |
Also for the price on machine work and all you may just look into aftermarket.
Wed May 11, 2016 9:21 am |
Wed May 11, 2016 11:55 am |
If they're in good shape very little machine work may be needed. I've got about $200 into mine, but if they'd needed a rebuild it'd be several hundred more dollars. You can also have them milled down to increase compression, which can be spendy. I recently heard about a place that does it for $200ish.
Wed May 11, 2016 12:19 pm |
Any key things to look for to help determine condition? Where did you have yours done Justin?
Wed May 11, 2016 12:35 pm |
Not mine... 1996 explorer 5.0 v8 motor gt-40 $700 http://denver.craigslist.org/pts/5553977114.html
Wed May 11, 2016 1:14 pm |
Wed May 11, 2016 1:21 pm |
If it needs new valves and guides with all the machine work you will be getting lose to 1k. In the end even the bottom of the line edelbrock e street heads flow better than gt40's. I paid $1023 for mine. Also the gt40's have large chambers on them(64cc) and most factory sbf heads on 351's were 60cc's. So unless you mill them down you will lose some compression. I just spent a good amount of time looking into this. Another option is trick flow makes heads that are already setup for flat tappet cams. Oh and that being said gt40's will need a spring change for a flat tappet cam. roller cams use different spring specs than a flat tappet cam.
Wed May 11, 2016 6:44 pm |
Wed May 11, 2016 6:55 pm |
you wont know if they need work unless you tear them down. you'll want to look at the valve seats and valves to make sure they are not pitted. Make sure the guides are tight.
Wed May 11, 2016 7:34 pm |
You should pull the gt40 heads take them to a good machine shop and ask they will tell you what they need. If you don't do anything to them you can flip them for profit and roll them into aftermarket.
It's just a pain to pull them out of the junk yard.
Wed May 11, 2016 7:35 pm |
Good advice. Thanks guys!
Wed May 11, 2016 7:43 pm |
plumbdoctor
I have a set of the F3z's gt 40's here I am looking to get rid of...they probably need a freshen up 150 and there yours...let me know
Wed May 11, 2016 10:31 pm |
Thu May 12, 2016 11:17 am |
[ 17 posts ] |
Users browsing this forum: Google [Bot] and 66 guests |
