Justin wrote:Curious why you don't want the P heads? You may have a slightly easier time finding some cheap and your Hut headers should fit them fine.
ZOSO wrote:Also for the price on machine work and all you may just look into aftermarket.
mickphatmac wrote:Not mine...
1996 explorer 5.0 v8 motor gt-40 $700
http://denver.craigslist.org/pts/5553977114.html
ZOSO wrote:If it needs new valves and guides with all the machine work you will be getting lose to 1k. In the end even the bottom of the line edelbrock e street heads flow better than gt40's. I paid $1023 for mine. Also the gt40's have large chambers on them(64cc) and most factory sbf heads on 351's were 60cc's. So unless you mill them down you will lose some compression. I just spent a good amount of time looking into this. Another option is trick flow makes heads that are already setup for flat tappet cams. Oh and that being said gt40's will need a spring change for a flat tappet cam. roller cams use different spring specs than a flat tappet cam.
plumbdoctor wrote:I have a set of the F3z's gt 40's here I am looking to get rid of...they probably need a freshen up 150 and there yours...let me know
