www.ColoradoClassicBroncos.com - View topic - 66 Wiki
It is currently Thu Nov 21, 2024 6:02 pm
Reply to topic  [ 88 posts ]  Go to page Previous  1, 2, 3  Next
 66 Wiki
Post Re: 66 Wiki
Sat May 07, 2016 5:59 pm
Post Re: 66 Wiki
That fuel pump is covered in grease and grime but it looks like it has a Carter brand name on it
Sat May 07, 2016 6:02 pm
Post Re: 66 Wiki
Next time I'm at Tony's I'm going to have my camera handy & take a bunch of pics. I'll look closer at his fuel pump. I wouldn't expect any fuel pump on any 66 to be factory, unless it was parked with very low miles.
Would an original pump be a Carter? or Ford branded? IDK.
Sat May 07, 2016 6:10 pm
Images: 2
Post Re: 66 Wiki
My fuel pump has 8 bolts. I have no clue if its original. Probably not. I can't see a brand name on it as it's covered in muck. Next time I'm under the Bronco I'll try and take some pics.
Sally
'66 Halfcab
Sun May 08, 2016 10:46 pm
Post Re: 66 Wiki
Ok, here is a new one. Apparently, some August 65 built Broncos have a shorter t-case shifter than the later built trucks. There may have been some short shifters on later trucks too.
Jeremy? Colby?
Thu May 19, 2016 12:40 pm
Post Re: 66 Wiki
1st day U13 on CB.com, different inner fender at firewall.
my inner fender not sure if its 100% original
Thu May 19, 2016 11:28 pm
Post Re: 66 Wiki
Fri May 20, 2016 3:21 am
Images: 2
Post Re: 66 Wiki
I saw the thread on CB.com about the short shifters. My U14, which I'm fairly certain was built day 1 of production, has a long shifter. I wonder if people didn't just cut them down because they were too long maybe? People often mistake the T-case shifter in my Bronco for the tranny shifter which gets annoying. Partly because it's so long I think. If they did come from the factory that way I would have to chalk that up to throwing together whatever they had on hand, which seemed to happen a lot in those early days.
Sally
'66 Halfcab
Sat May 21, 2016 4:23 pm
Post Re: 66 Wiki
My shifter is quite obviously cut short. The weld & grinding work is visible, along with a slight kink.
Bajabronco, Delconick, and eaglenest66 say the short shifter is a real thing, so I believe it. They all know their stuff. Must have been the old 66 switcharoo parts game.
Sun May 22, 2016 9:23 am
Post Re: 66 Wiki
I've read in a few places that the short shifter was a later '66 thing. It came about after owners continually slapped their D20's out of gear while shifting to 1st and 3rd on the column.
Of course there's no way to prove that. But seems like a reasonable explanation.
Sun May 22, 2016 9:34 am
Post Re: 66 Wiki
Sun May 22, 2016 11:55 am
Images: 2
Post Re: 66 Wiki
Yeah I tend to agree with that sentiment in some cases. The long t-case shifter gets in my way sometimes so I could totally see people requesting they be swapped at the dealer or cutting them down themselves. I have no doubts there are probably some out there from the factory too, given all the "variation" that accompanied the 66's.
Sally
'66 Halfcab
Sun May 22, 2016 10:11 pm
Post Re: 66 Wiki
Fri Jun 24, 2016 7:33 am
Post Re: 66 Wiki
The T case shifter screws in and out easily so I bet they got swapped out on a regular basis. Plus I bet at that time a lot of people just took them out and shorten them themselves if it was a problem. I used to hit that shifter all the time before Phil and I swapped the C4 and my 66. Image
Sun Jun 26, 2016 10:11 am
Post Re: 66 Wiki
Thanks for the pic. My friend's truck is a shorter shifter, it was only about 12" out of the floor. I think the shifter I got is long.
Sun Jun 26, 2016 2:15 pm
Post Re: 66 Wiki
Following this one....
Quick Question -- What's a Budd Body?
Go Hard or Go Home
Thu Aug 18, 2016 8:06 am
Post Re: 66 Wiki
Thu Aug 18, 2016 11:49 am
Post Re: 66 Wiki
Super cool! Thanks much -- Mine is an Oct build month, so I guess that's what I have. I honestly had no idea that there were SO many unique features on the '66! This is gonna be fun.
Go Hard or Go Home
Thu Aug 18, 2016 5:00 pm
Post Re: 66 Wiki
I didn't know any of this stuff till I bought my 66, and started researching it all. I was amazed how much stuff got changed out on my truck with just 57k on the odometer.
Thu Aug 18, 2016 5:08 pm
Post Re: 66 Wiki
Go Hard or Go Home
Sat Aug 20, 2016 10:17 am
Post Re: 66 Wiki
Funny you mention that. I just looked at a very nice 65 Camper Special F250 yesterday at the pre-Gunnison Car Show, last night. It had lots of stuff from the 66 Bronco- knobs, door handles, shifter & turnsignal knob, fresh air inlet doors. It had a horn ring, but wasn't the same as the Bronco. I'm headed to the real show right now, I'll take some pics.
Sat Aug 20, 2016 10:20 am
Post Re: 66 Wiki
There were 2 1965 F250s at the show today. The Camper Special is freshly restored, and done really well.
66 arm rests (but colored matched to the interior, not black), window & door handles, radio, dash controls knobs, turn signal & shifter lever & air vent doors in the kick panels.
Horn ring has 3 spokes & a very different horn button/emblem
The original, non-Camper Special had a 300 I6 (first year for that motor) and less options. Recognize the speedo?
Sat Aug 20, 2016 8:21 pm
Post Re: 66 Wiki
This is awesome!!! and that first truck.... holy crap!! I'm in love..
Go Hard or Go Home
Sat Aug 20, 2016 8:38 pm
Post Re: 66 Wiki
I'm going to guess the fuse block is the same as well.
The problem with the steering wheel is the F series is deeper from where the driver grabs it to where it mounts to the steering shaft. This deeper wheel creates a steeper angle and would make the F series horn ring stick out badly on a Bronco wheel.
Sat Aug 20, 2016 9:33 pm
Post Re: 66 Wiki
I just wanted to bring this to attention. I know Viper has seen it.
Maybe the 2nd Bronco ever built. He's sure not putting up many pics though. Only the VIN tag.
http://classicbroncos.com/forums/showpo ... tcount=142
popcorn
His intro thread:
http://classicbroncos.com/forums/showth ... p?t=269890
Sat Aug 27, 2016 4:47 pm
Post Re: 66 Wiki
That's so cool
Sat Aug 27, 2016 7:51 pm
Post Re: 66 Wiki
Added pic of 'access hole' & rubber plug in early inner quarter panel. Also short vs tall t-case shifter.
Sun Oct 02, 2016 9:32 am
Post Re: 66 Wiki
Chad, I noticed the discussion about 66 wheels over on CB a few days ago. What wheels does yours have? I have one of the less common style and 4 of the others. I wonder if they were the spares originally?
Mon Oct 03, 2016 7:54 am
Post Re: 66 Wiki
I'm glad someone asked. They aren't paying attention to what I'm posting over there. In my opinion, none of his rims are correct 66 rims. Here's the thread:
http://classicbroncos.com/forums/showth ... p?t=270916
My truck had wagon wheel rims on it when I bought it.
This is the opinion I've formed from looking at roughly eleventy bajillion 66 pics in the last year. And also from date stamps on some early rims I got from Don Allison. I haven't read it anywhere in actual writing, posted by anyone, anywhere. So I could be wrong.
There are two style of rims, early (66-67 Broncos, and ?65-?? 1/2 ton pickups I think) and late (68 on). Forget the K/H stamp for a minute. The difference is in the window or opening shape
Early:
Late:
I went through EVERY rim Don Allison had, looking for the early style with K/H stamps. There were at least 2 other rims with the same style, with no K/H stamp. The one I bought has a KW stamp. I have early style with K/H stamps dated 66 & 67. Someone over there commented that the K/H should be straight across from the Ford logo. One of my K/H stamped wheels has the Ford logo 90* from the K/H instead of straight across. It still has a tire on it, so I can't see the date stamp.
The "Late" rim pictured above is Landshark's, it has the K/H, but it's the newer style window, and dated 68. On CB.com everyone is caught up looking at the K/H, and I think they are missing the point. I'm willing to bet the thread's owner has a bunch of 68 K/H rims. He now thinks they are super special 66 rims.
Mon Oct 03, 2016 12:16 pm
Post Re: 66 Wiki
Also, some of my 'early' K/H rims have markings (scratches) that match the 66 hubcap retainer pattern. So I'm pretty damn sure they were on 66 Broncos.
Mon Oct 03, 2016 12:19 pm
32,925,538 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
