www.ColoradoClassicBroncos.com - View topic - 72 Red Explorer Sport
It is currently Fri Nov 22, 2024 4:03 am
Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
Post Re: 72 Red Explorer Sport
Thanks. I'm going to have the guys from work look and see what they think.
I sprayed the cheaper solvent based paint for a test card today. I noticed they had the formula in the newer water based paint. I might try that too, its surprising how different they can come out. The water based stuff is 4x more expensive.
Fri May 27, 2016 6:35 pm
Did you translate the "T" paint code from Broncohio?
Fri May 27, 2016 8:35 pm
Broncohio says T=Candy Apple Red, our BASF mixing system said T=Candy Apple Red, Ford 66-79, so it's the right color.
I might have blown the mix, I mixed a very minimal amount, in between coats on a car I was painting. Our paint booth was recently upgraded and we are moving a lot more air through the booth. But this has made the space around the booth drafty. Our scale is sensitive enough to be affected by this added air flow. I think I might have missed the mix by a +/-0.1 grams of one toner due to the draft. In 18 oz you'd never see it, but in 2 oz it can make a big difference. I'm going to mix it again, maybe 6 ounces, without the booth running.
I've been reading about Candy Apple & looking at pics, and it's not a bright red, like my test panel.
Fri May 27, 2016 8:43 pm
I'd think that your inner door panels and inner tailgate would still be pretty true to the original color.
Here's one that I removed the 70's carpet from and it looks a lot like yours.(it was also a candy apple red)
Sat May 28, 2016 9:11 pm
Lots of good paint on this one, looks a lot like that pic.
I found a couple more "paint OK" stamps.
One on the driver's fender
One under the steering column, on the lower lip of the dash
Sat May 28, 2016 11:22 pm
One of 141 Candy Apple Red Explorer Sports.
I guess I don't know how to change a pdf to a picture.
Wed Jun 01, 2016 11:37 am
32,941,701 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
