It is currently Fri Nov 01, 2024 10:30 am
[ 16 posts ] |
Mustang h-boost & 4x4x2 gear fitting sizes, cooler placement
I'll start searching, but I figured someone here might know.
I need the easiest way to make up lines from a Saginaw p/s pump, to a Mustang GT h-boost unit, & 4x4x2 box (also which port is pressure side & which is return side). Need fitting sizes & suggested methods, kits, etc. I don't know if I can have this stuff made here locally.
Also where does a p/s cooler fit in the mix? Diagram?
Thanks.
Sun Jun 05, 2016 7:34 pm |
Re: Mustang h-boost & 4x4x2 gear fitting sizes, cooler place
Follow up question, I've never worked with -an hose. Can Russell hose be used with Aeroquip fittings? Or are things proprietary?
Sun Jun 05, 2016 8:02 pm |
Sun Jun 05, 2016 8:59 pm |
Thanks for the info. Best way to cut the stainless braided hose? Sharp metal chisel? Here is a pretty good list of stuff needed for the Mustang and maybe the Super Duty h-boost. Specifically, the special adapters Hydratech (PN HBS9106) sells. http://classicbroncos.com/forums/showpo ... ostcount=4http://www.hydratechbraking.com/hose_fittings.html
Sun Jun 05, 2016 9:05 pm |
Sharp chisel works and so does cutoff wheel.
Sun Jun 05, 2016 9:18 pm |
This video will explain pretty well how to make your hoses. It's actually pretty easy. https://m.youtube.com/watch?v=PeeflgGlenY
Sun Jun 05, 2016 9:25 pm |
For hose and fittings check out http://www.anfittingsdirect.com Im running their ptfe stainless lines and fittings in my can and have yet to have an issue. Also a lot cheaper price wise. Im getting ready to place my order for some -6 and fittings for my HB and fuel system. Also a local Colorado company.
Mon Jun 06, 2016 5:50 am |
Mon Jun 06, 2016 6:35 am |
Thanks for all the great info!
Mon Jun 06, 2016 7:21 am |
Mon Jun 06, 2016 10:03 am |
Mon Jun 06, 2016 12:03 pm |
Any advice regarding the special vice insert that holds the fittings? Will hard plastic or wood work to do a few?
Mon Jun 06, 2016 12:20 pm |
I used wood when I did mine
Mon Jun 06, 2016 12:58 pm |
x2. I used a chunk of 2x4. Worked great.
Mon Jun 06, 2016 3:45 pm |
if you go ptfe you dont need a vice to assemble them. They use a compression style fitting.
Mon Jun 06, 2016 6:00 pm |
So I have the 2 steering boxes disassembled. What should I do while its open? I have the seal kit.
4x4 sector shaft is good, no scoring.
Fluid from the 4x2 box was grungy.
Thu Jun 09, 2016 3:01 pm |
[ 16 posts ] |
