www.ColoradoClassicBroncos.com - View topic - Help identifing a Saginaw pump.
It is currently Fri Nov 01, 2024 12:22 am
Reply to topic  [ 2 posts ]
Post Help identifing a Saginaw pump.
This pump was part of a power steering upgrade kit the PO put on the truck. I've identified the other bits, like the steering gear, but not sure about this pump.
Obviously it is a Saginaw pump, I can tell it is newer because it has a GM O-ring fitting on the output vs. the older inverted flare, but other than that, I have no idea about the application. I was hoping someone would recognized the return line and can shape and could name an application.
AND unrelated, but look at this gem I saw at the boneyard while pulling parts for the hydroboost.
Mon Jun 20, 2016 10:49 pm
Post Re: Help identifing a Saginaw pump.
I'm digging the "slotted rotor" in the second pic, I just gave one of those canned hams away at the swap meet...IIRC, I pulled it from a Chevy 1500 mid to late 80's
Hope that helps
Tue Jun 21, 2016 1:32 am
32,736,929 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
