www.ColoradoClassicBroncos.com - View topic - New electrical gremlin
It is currently Thu Oct 31, 2024 10:38 pm
Reply to topic  [ 6 posts ]
Post New electrical gremlin
So went wheeling this past weekend and ran into a few snags (and some trees as well). New issue is I cracked a fuel line and had to drop the tank. Used the in tank pump to drain some fuel after I fixed the tank so it was easier to put back in place. I did start it and moved the truck. Next day went out and no fuel pump. After some searching I did find my fuel pump fuse was blown. Replaced it but everytime I turn the key to prime the pump it blows the fuse. Any ideas?
Fri Jul 08, 2016 9:50 pm
Post Re: New electrical gremlin
Fuel cools the pump. If you run it without fuel it could have overheated.
Fri Jul 08, 2016 10:03 pm
If you pulled the tank and put it back in did you loosen any other electrical connections, like the ground wires or nick / pinch a wire?
Sat Jul 09, 2016 11:46 am
I'm with Kinder most likely a pinched or grounded power lead.
Sat Jul 09, 2016 2:23 pm
Profile WWW
I'll have to drop and check. I don't think so but you never know.
Sat Jul 09, 2016 6:12 pm
I unplugged the fuel pump and turned the switch and no blown fuse. Must be something with the wire to the tank, pump, or something
Sun Jul 10, 2016 11:33 am
32,735,975 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
