www.ColoradoClassicBroncos.com - View topic - Old style ignition woes....
It is currently Fri Nov 01, 2024 6:35 am
Reply to topic  [ 14 posts ]
Post Old style ignition woes....
I need help... And not - it's not a Bronco -or even a car this time
Yeah, that kind of help too, but that type is not what I came here to ask for
I have a 1966 StarCraft boat that was given to me. It has four-cylinder inboard outboard motor that two years ago ran fine, then last year started having starting issues. now I can't even get it to crank I have replaced the starter the solenoid and the ignition switch battery is charged and I can't get it to crank Let alone try to start
Does anyone want to come help me troubleshoot this thing? preferably someone who has great ideas on how to make This old stuff run.
Yeah, it has points. And no I have not replaced them yet. I figure tune up comes after it turns over
I'm pretty sure we can get food and beverages from my missus in exchange for your expert advice and assistance. I'm thinking tomorrow (Sunday) at this point. Considering we still have Daniels truck torn apart replacing the water pump and I'm about to start drinking.
Sat Jul 16, 2016 5:51 pm
Post Re: Old style ignition woes....
Does it make any kind of noises? Starter seized?
Sat Jul 16, 2016 6:05 pm
I can promise you this, there is a lot less stuff I. The way when working on this old boat
Sat Jul 16, 2016 6:06 pm
Sat Jul 16, 2016 6:07 pm
Maybe the wires have corroded further down the sheathing?
Sat Jul 16, 2016 9:32 pm
Sun Jul 17, 2016 11:58 am
Can't speak for old boats, but I had the fusible link cook on my rig prior to me owning it.
Sun Jul 17, 2016 2:51 pm
Yeah, I'm starting to believe this is a likely possibility. The good news is, there is even far less wires in this boat than out broncos ever had.
I don't think there are any fuseable links in the boat at all (thankfully)
So hopefully tomorrow evening I can start replacing wires. Sooner or later the engine will turn over.... Right?
Sun Jul 17, 2016 9:15 pm
Take everything out of the loop besides the starter & battery to confirm starter turns over. Once this is confirmed I'd start running continuity tests on wires, once this is done check ohms (using standard specs). The prob will turn up in one of these steps.
Tue Jul 19, 2016 11:48 am
Can you get the engine to turn over with a wrench? Is the engine seized?
Did you winterize it with antifreeze? (cracked block/rust)
Tue Jul 19, 2016 12:24 pm
Tue Jul 19, 2016 12:39 pm
Tue Jul 19, 2016 12:41 pm
Oh yea!
New starter (x2)..... Nope
New solenoid .....nope
New ignition .....nope
Replaced wires from solenoid to starter.... Nope
Replaced power from battery to starter and ground too.... Nope
Built a ground cable from starter mating bolt to battery ground......oh yea foshizzle
Pulled new (2nd new actually) starter to test, grounded the case and zoom zoom
Who new, new starter does not ground directly to the block. She's grounded now
Sat Jul 23, 2016 4:39 pm
Awesome!
Wed Jul 27, 2016 8:10 am
32,741,314 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
