It is currently Sat Nov 23, 2024 8:28 pm
TOOLMAN
Fri Sep 09, 2016 7:22 am |
Pulled it out of my garage with the full soft top installed. This was excellent news, as I wasn't sure that was possible.
Fri Sep 09, 2016 9:04 am |
Replaced leaky valve cover gaskets with non-leaky new ones. New ones are high tech rubber and thinner which meant a little more grinding inside the valve covers (I could see a little contact was happening already) and some bolt shortening.
Replaced the full race valve body with a gentler one. The old C4 looks pretty good inside after 40K miles. I also swapped the stock pan for a B&M with a real filter. I had to massage the dipstick tube to fit. It's too close to the exhaust. 20160916_172949.jpg Bronco 004.jpg
Fri Sep 16, 2016 7:35 pm |
Since im still waiting on my brake parts to arrive I decided to roll the bronco out and pull the cage. Set the carpet back in and bolted the cage back down. Hoping this week will allow me time to install the seats and center console. Will have to modify the console to house my new switches and jb fab twin stick.
Mon Sep 19, 2016 2:30 pm |
cravenbronco
I was able to get the cage and the bed cleaned up and painted. Looks a lot better than it was. It's a win in my book.
Thu Sep 29, 2016 7:21 pm |
horseplay
Looks nice congrats
Thu Sep 29, 2016 7:32 pm |
Looks good!
Thu Sep 29, 2016 11:28 pm |
Looks nice. I really like that roll bar & spare tire mount!
Fri Sep 30, 2016 7:35 am |
Got the taurus fan wired in. Had to replace my brand new master cylinder with another. Bled, Bled, Bled, Bled, and still needs more. I have a gallon through this system and still cant get a firm pedal. I'll bleed some more in the morning then take it for a spin around the block.
Fri Sep 30, 2016 11:06 pm |
cravenbronco
Sat Oct 01, 2016 12:26 am |
Went to a big sale the local scrap hauler had. I know him from working at the bodyshops but have never been to his house/yard.
I came home with a nice deal on a spare ZF, just in case, you know. And a blue Ranger rear bench seat in very nice condition. A little wear on the back, but I think it will clean up nice. No obvious rips or tears.
Tried to buy a 79 kingpin 60, but he knew what it was worth.
He has a real nice 70 Bronco, very stock, almost no rust. Sorry no pics. He wasn't interested in selling, he also said someone had recently told him it was worth $15-$20K. I told him I agreed. We talked about putting an overdrive trans in. He had another ZF in an F250 & a couple M50Ds, we talked about those as options.
He had a couple nice bump side, a 4x4 F250 and a 2x4 half ton, both 8' beds, rough but not rusty.
Sat Oct 01, 2016 7:24 pm |
Nice score(s) Chad
Does Gunni have the highest Bronco per capita or do you just know where they are all at ?
Sat Oct 01, 2016 7:36 pm |
Sat Oct 01, 2016 7:42 pm |
Hunting/backcountry rigs...it makes sense there!
Mon Oct 03, 2016 9:01 am |
Mon Oct 03, 2016 8:12 pm |
Not wrecked, just long abandoned. Very solid startsNot sure the F250 was for sale, I could ask. But the 1/2 ton (can't remember if it was an F100 or 150) had $900 written on it. Mostly complete really. I knew I should have taken pics.
I did have Molly take pics of this. I know you were talking about DeSotos, this would make a very cool family truckster. I think it's a 46. It didn't have a price on it either.
You can see the 70 Bronco in front of the shop building in the background!
Mon Oct 03, 2016 8:31 pm |
That's a beautiful blue on that bronco. I like the desoto too.
If you happen to be by there again inquire about the 250 and take pics of both for me if you would be so kind.
Mon Oct 03, 2016 8:53 pm |
Will do.
Mon Oct 03, 2016 8:54 pm |
cravenbronco
Got a new Led Light bar for the half cab. I had to make a bracket so I could attach it to the roll bar. Got it painted and all mounted up. Wiring came out better than I originally thought. All good and on to the next project
Sat Oct 15, 2016 7:30 pm |
pgilbeau
Got my full width loaded up and taken to get re-geared, etc.
Sat Oct 15, 2016 8:15 pm |
cravenbronco
Sat Oct 15, 2016 8:26 pm |
Replaced the power steering pump for the 4th time since March.
The gal at Oriellys (Natasha says hello Phil) said that it's a big problem right now. All the parts stores get the reman pumps from the same two reman companies who are in a price war. So, the reliability has went to hell as they cut corners on the rebuilds.
Fri Oct 21, 2016 6:33 pm |
I'm really getting tired of this.
The decline of quality is accelerating in the name of greatest profit and people's own cheapness.
Fri Oct 21, 2016 10:08 pm |
rt9
Bought a brake booster and found these sweet license plates. Sent from my SM-G860P using Tapatalk
Sat Oct 22, 2016 7:14 pm |
That's a good place to get them. I bought my set there years ago. Do yourself a favor and shoot a couple coats of clear coat over them. Mine started rusting within a few months.
Sat Oct 22, 2016 7:16 pm |
rt9
Good idea. Thanks. Turns out after talking to the owner, my wife grew up around the corner from him and they talked forever,,, kinda awkward. Lol. Also saw a guy in a nice Green 71 named Mike Richards or Rogers or something like that. Real nice guy. We just love Manitou.
Sat Oct 22, 2016 7:23 pm |
Lobobronco
Joined: Wed Sep 29, 2010 9:20 am Posts: 289 Location: Denver, CO
Good Afternoon All, Got a new fuel delivery device installed and now it runs better than ever! No longer 3 pedaling it at a stop light! Also decided I might need some tunes and found a 10a fuse blown. Didn't have one so now my wife has no seat heaters ! Cruised it around the new town and parked it in the new driveway! Have a great weekend!
_________________ Her name is Lucy...and well...that's who she is!
Sat Nov 05, 2016 5:24 pm |
Unaweep
I put in a new clutch and rebuilt the D20 a couple of years ago- but even with my feet pushing on the shift stick it was really hard to shift in/out of 4x4. I thought perhaps I'd messed it up.
I put in the JB custom Fab twin stick conversion this week and took it for a test drive....no problems now.
First time I've done anything to the Bronco in a year...
Thu Nov 17, 2016 5:06 pm |
cravenbronco
Got my new axle bump stops installed on the 66. Hopefully the driveshaft stops hitting on the oil pan. Fingers crossed
Sat Nov 26, 2016 2:40 pm |
rt9
Finally got my power booster installed. Thanks Phil (pgilbeau). Also found this cool club plate buried in my barn. Sent from my SM-P600 using Tapatalk
Sun Dec 04, 2016 5:29 pm |
