Register •
FAQ
• Login
It is currently Sun Sep 29, 2024 12:23 am
[ 5 posts ] |
Brake pedal nylon sleeves and washers
I am repairing my clutch linkage from the pedal to the master cylinder and will be using a threaded brake rod since I am using a brake pedal assembly for my clutch. Does anyone know where I can get the nylon sleeves that are used on the brake light switch and rod? I looked locally but don't see them listed at the parts stores, just the brake light assembly. Maybe my search skills are lacking?
Sat Sep 24, 2016 9:39 am |
Re: Brake pedal nylon sleeves and washers
Sat Sep 24, 2016 9:57 am |
Saw those Iam going to check around at a few parts stores but will probably end up ordering online
Sat Sep 24, 2016 10:00 am |
I have the bushings that go in the pivot if you need.
Sat Sep 24, 2016 5:37 pm |
Appreciate it. I couldn't find any locally so I picked up a couple of nylon spacers and reamed one out. Seems to work but I will just order a real one to make a swap easier
Sat Sep 24, 2016 6:49 pm |
[ 5 posts ] |
