Gunnibronco wrote:First question is about adding headlight relays to the harness. Should I run new, heavier wire to the headlights or can I just tap into the harness & feed the headlights through the Centech wiring. I'm assuming the Centech wire is adequate. And just adding the relays will help my headlights.
Since I'm using a 3G alternator & no amp meter, I have no real use for the heavy yellow wire that went to the "Batt" terminal on the stock alternator. Can I remove it from the back of the Centech fuse panel & use it to feed my extra fuse panel? The heavy red wire will feed the panel from the + terminal on the battery. Right?
What size fuse should I use to run the whole truck.
I want to use a Mega fuse holder I have to run the whole truck (except winch).
I'd run the Centech harness, EFI, headlight harness, & a 5 fuse aux panel (cb, and future stuff) fed by a 10g wire.
Gunnibronco wrote:My question now is about wire/fuse sizing. If I followed the 'max fuse charts' I find on-line, the Centech harness red wire is 10g, and would use a 30a fuse. The EFI harness is 12g and would use a 20a fuse. I have a bunch of 8g wire here, that would use a 50a fuse. I'm wondering why you chose such a high amp fuse for your Centech?
Gunnibronco wrote:Getting into the engine compartment, I don't think I have a place for the following wires:
"COIL +","IGN PWR", & "START" all come from one 3 wire weatherpack. I have another "START" wire that I think should go to the "S" terminal on the starter relay.
Also "REG S" seems like it went to the old stock regulator maybe. Since I'm running 3G I don't think I need it.
