It is currently Sat Jun 22, 2024 9:15 pm
[ 21 posts ] |
Centech & RJM harness questions
I've completely unwrapped & disassembled a perfectly good Centech harness.
I have a few questions, as I customize it for my set up, and try to remove as much extra wiring that I can.
First question is about adding headlight relays to the harness. Should I run new, heavier wire to the headlights or can I just tap into the harness & feed the headlights through the Centech wiring. I'm assuming the Centech wire is adequate. And just adding the relays will help my headlights.
I'm also developing a list/ball of wire that I figure I can pull out of the harness completely. I'll add that list later, to make sure I'm not pulling out something vital.
Thanks
Sat Oct 01, 2016 6:56 pm |
Re: Centech harness questions
Also, can I find the alternator trigger wire inside the cab on an RJM EFI harness?
I want to run an alternator light and would rather pull the wires from under the dash than run them from the engine compartment back into the cab and back to the engine compartment.
Sat Oct 01, 2016 7:00 pm |
Re: Centech & RJM harness questions
Headlight relays are best done under the hood. That's where you will tap into the high current and you can use the existing headlight wires (only need one side only) to trip the relays.
RJM should have the green alternator wire you need. The other end of it goes to one of the relays.
Sat Oct 01, 2016 9:14 pm |
Thanks,
What gauge wire should run from the relay to the headlights? I have something you posted that says it needs a 20 amp fuse to the relays. So a 12g feed to the relay should be ok?
I am using the green wire in the RJM harness for the alternator. I just couldn't locate it once inside the cab. I'll keep looking & check out the relay pack.
Sat Oct 01, 2016 10:37 pm |
12g is fine.
Sat Oct 01, 2016 11:13 pm |
Thanks, things are coming along. I've pulled A BUNCH of unnecessary wire from this harness.
Since I'm using a 3G alternator & no amp meter, I have no real use for the heavy yellow wire that went to the "Batt" terminal on the stock alternator. Can I remove it from the back of the Centech fuse panel & use it to feed my extra fuse panel? The heavy red wire will feed the panel from the + terminal on the battery. Right?
Sun Oct 02, 2016 6:13 pm |
What size fuse should I use to run the whole truck.
I want to use a Mega fuse holder I have to run the whole truck (except winch).
I'd run the Centech harness, EFI, headlight harness, & a 5 fuse aux panel (cb, and future stuff) fed by a 10g wire.
Thanks
Fri Oct 07, 2016 10:45 pm |
Sat Oct 08, 2016 9:54 am |
Thanks for the suggestions.
I've already started the headlight wiring as you and Viper suggested. Using the Centech harness as the signal wire to the relay & 12g for the headlight power.
Real good point about keeping the fused amps lower. I hadn't thought of that.
I'm trying to keep wiring minimal under the hood, and I don't want a bunch of in-line fuses hanging off the battery. I don't have a good under hood distribution block or a good place to put one. I have 2 Mega fuse holders and I'd like to use them under the hood.
My question now is about wire/fuse sizing. If I followed the 'max fuse charts' I find on-line, the Centech harness red wire is 10g, and would use a 30a fuse. The EFI harness is 12g and would use a 20a fuse. I have a bunch of 8g wire here, that would use a 50a fuse. I'm wondering why you chose such a high amp fuse for your Centech?
I'm thinking using 2x 50 amp fuses & run 8g through the firewall to behind the dash (about 2-3' of wire, max since my battery is recessed in the cowl now).
1x 50a fuse to feed the Centech harness (10g/30a) and headlight harness (12g/20a)
1x 50a fuse to feed EFI harness (12g/20a) and aux fuse panel (wire/fuses tbd)
Thanks again for all the help guys. I seem to be treading more water with this wiring than I thought I would. Finally found some 1/4" female terminals that snap into the relay bases I bought. Now I can get back to wiring.
Sat Oct 08, 2016 1:13 pm |
Sat Oct 08, 2016 5:24 pm |
Thanks, its good to know how OEM does it in the real world. I think I'll wire it with 2 Mega Fuses & 8g. I'll probably start with 60a on each.
Sat Oct 08, 2016 6:20 pm |
Getting into the engine compartment, I don't think I have a place for the following wires:
"COIL +","IGN PWR", & "START" all come from one 3 wire weatherpack. I have another "START" wire that I think should go to the "S" terminal on the starter relay.
Also "REG S" seems like it went to the old stock regulator maybe. Since I'm running 3G I don't think I need it.
Sat Oct 08, 2016 7:20 pm |
Also, off the "REG S" wire there are 3 wires labeled "DIST MOD", "CHOKE", & "IDLE SOL". These wires seem to have no home either.
Sat Oct 08, 2016 7:39 pm |
Obligatory Centech/wiper switch question.
I'm trying to splice the Centech harness to my Bronco switch pigtail & intermittent wiper switch. Their instructions are about as clear as mud.
My switch pig tail has the following wires:
Black Black Blue White Orange/white stripe Green/black stripe Red
The Centech harness has: Black-park switch Red- Park power White- Low Blue- Hi ?I forget- Washer pump
Thanks
Wed Oct 12, 2016 7:35 pm |
Wed Oct 12, 2016 9:56 pm |
Yes, it's a tangled mess. I'm surprised how much excess wire I've pulled out. It's pretty bare bones now. I backtracked all the wires I don't need to 2 fuses: IGN SYS & ALT/EMM. From what I can tell, I don't need them at all, so I freed up 2 circuits with 12v key in 'Run' or 'Start'. I used the IGN SYS circuit to turn on the EFI (orange wire on RJM) & supply 12v to the winch & air compressor switches. I still have not used anything off the ALT/EMM wire. I need to hook up my CB, just can't decide if I want it to be switched or hot all the time.
Thanks for the help.
Wed Oct 12, 2016 10:07 pm |
Even centech's own description of the wires adds to the confusion. I sure wish someone would make a diagram for it. I get a lot of questions on the centech wires but the different color scheme and poor instructions make it nearly impossible. I wish I was more helpful with this.
centech white=bronco white-orange centech blue=bronco blue centech red =bronco red centech black=bronco black-white
Hey, those make sense.
Match those colors to the terminals on this diagram for a '70s wiper delay. An '80s delay will need one of the washer wires moved (unless already done) as I recall.c-301.JPG
Wed Oct 12, 2016 10:20 pm |
Thanks! I'll check it all out tomorrow.
Wed Oct 12, 2016 10:30 pm |
Thanks for the pic. My old Bronco switch pigtail wires were mostly the same, except circuit 950 is Black, and 58 is White. Here is what I did, sorry no graphic design skills here. Bronco Wiper Switch Pigtail ----> Centech Harness950 Bk & 763 O/W---->O "Wiper Switch Pwr" 951 Gr/Bk---->Gr "Wash" 56 Bl---->Bl "High Speed" 28 Bk---->Bk "Park" 58 W---->W "Low Speed" 63 R---->R "Return" I think this makes sense. Hopefully I don't let the magic smoke out of anything when I power it up. It will be a minor miracle if everything works, after all the hacking I've done. Knock on wood.
Thu Oct 13, 2016 8:22 pm |
Looks ok to me.
Thu Oct 13, 2016 10:39 pm |
I was just reading someone's post on FB regarding Centech & wiper motor wiring. I tried to answer his question, and had to go look at my truck to verify. I'm now wondering if I wired my motor correctly. This is what I did, please tell me if I have this right. He thought the red & blacks should be reversed from what I did.
Centech color/description-----> Motor wire color/Centech's description White/low speed ----> White/low speed Blue/high speed ---->Blue/high speed Red/park power ---->Red/park Black/park switch ---->Black/motor stop
Sun Aug 12, 2018 12:34 pm |
[ 21 posts ] |
