www.ColoradoClassicBroncos.com - View topic - What front springs with a winch?
It is currently Tue Oct 01, 2024 3:32 am
Reply to topic  [ 11 posts ]
Post What front springs with a winch?
I'm going to replace my 80's suspension lift, currently 3.5 and very stiff.
I have a 351W and plan on adding a winch and some bigger bumper later.
I'm going 3.5" lift, so what springs do you think I should get on the front?
(may be going 4 link on the rear with leaf springs). EDIT - I meant rear coil springs, not leaf.
Driving is around town, mild 4x4ing and camping/hunting/Moab stuff.
Its hard to tell with out riding in a vehicle set up.
Erik
Thu Jan 19, 2017 4:13 pm
Post Re: What front springs with a winch?
I've got basically exactly what you are planning to do. I just replaced my suspension. You're welcome to take a ride Saturday if you'll be at the breakfast.
Thu Jan 19, 2017 6:21 pm
Hey Mike did you get your new roller cam set up installed? If so how much of a change did it make on the highway.
Thu Jan 19, 2017 7:56 pm
Profile WWW
Thu Jan 19, 2017 8:00 pm
What tire size are you planning to run? Also, why the leaf Springs if you link it?
Fri Jan 20, 2017 7:39 am
Fri Jan 20, 2017 11:41 am
I'd match the front and rear springs for the lift. If you're going to link it later you'll be able to adjust rake if the springs sag a little.
Fri Jan 20, 2017 11:43 am
Fri Jan 20, 2017 1:55 pm
Fri Jan 20, 2017 2:17 pm
One option you might consider is going to coilovers if you've got the fabrication skills. I'm running spring rates that are a chunk lower than most of the available springs. The front soaks up bumps beautifully and I'm looking forward to linking the rear. Longer arms also makes a difference in ride quality if you haven't done that.
Fri Jan 20, 2017 2:39 pm
32,407,746 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
