rooster wrote:Hey guys, been a while since posting on this board,
I recently picked up a HP dana 44 and big bearing 9" from a 76 f150.
I have a couple of questions about the swap, first off can I swap over the ARB I already have in my 44 now being that it is a low pinnion axle? Shouldn't matter correct?
Also the gearing is a 3.50 and I need to swap to 4.11 to match the 3rd members I will be putting in the rear, I have no experience swapping a R&P , do you think it would be easier/ cheaper to try and trade my front axle for one already set up with that ratio?
,mine was the weld on wedges , I wouldn't be opposed to just moving the spring towers outward but wanted to see what everyone was doing in regards to moving wedges in vs towers out. Also have BNG long arms
Thanks
rooster wrote:Do you guys think that for a mildly juiced up 351 the 411s would work ok with 35s? Will also be running zf5 and plan on driving bronco 75 % street , 25% trail
Also how do you like full width axles for on road use?
Thanks
Thanks
