Viperwolf1 wrote:E2000 Airtex pump will replace the hp pump on the frame. How well is the lp pump doing now? I like the Carter P4070 pumps.
Jesus_man wrote:Eck - Thanks! I did order the E2000, but from amazon to use my prime shipping and price was within a dollar. I also ordered the Carter P4070.
Rob - The HP pump is located just below the brake master cylinder. I could move it back easy enough, but I worry about stressing the HP pump as even the OEM setup was an LP in the tank and an HP on the frame rail.
I know I need a new fuel pump relay. Oddly enough, I found a youtube of a guy who had fuel problems on his 87 F-150. Turned out the relay had fallen out of it's holder and was lying horizontally. Once he put it back into it's holder, the truck fired right up. I experienced the same thing in Moab in 2012. So why the heck would these relays care which way they are oriented?
I have a spare in my ammo can that I take with me, but a gallon jug of gear oil ruptured and soaked that relay in oil. I don't recall if I tested it or not.
Jesus_man wrote:I do not. I may ask my dad if he can find any on the relay.
Gregg wrote:I have 2 High pressure pumps in my Bronco....One is really close to the rear tank and the other one is all the way up in my spare parts box.
Jesus_man wrote:And something to do with the relay having to be upright is driving metoo.
