www.ColoradoClassicBroncos.com - View topic - Explorer -> Superduty power steering upgrade
It is currently Tue Oct 01, 2024 7:41 am
Reply to topic  [ 8 posts ]
Post Explorer -> Superduty power steering upgrade
My explorer pump in the 76 is making the dreaded whining noise - seeing how I will be doing some work on the Bronco in the next week I will be adding the power steering pump to the list of things to fix.
I was thinking of doing the superduty upgrade and swapping the internals, has anyone done it? did it work well? I am running the stock 76 power steering box only at the moment, however i have a hankering to change the vacuum brakes to hydroboost here soon.
The upgrade I am thinking about doing is this one: http://classicbroncos.com/forums/showth ... 617&page=2
thoughts?
I have a spare exploder pump on the shelve as well.
Fri Jan 27, 2017 7:17 pm
Post Re: Explorer -> Superduty power steering upgrade
Have been seriously considering it. Let me know if you want to knock out both pumps at the same time.
Fri Jan 27, 2017 7:46 pm
I've looked for better pump to fit in the explorer bracket. I think I have found a good candidate but it's still going to require some fabrication.
The pump is a ZF from a 2004 cummins 2500. The bolt pattern is the same and it puts the input and output in the same position. It needs a fitting made to hook up the suction hose and I don't know about shaft size and pulley fitment. I need to find a cheap used one to further explore the possibilities.
I think it would be more than enough pump if it would work. Those dodges had hydroboost and huge steering boxes.
Fri Jan 27, 2017 9:47 pm
I will look and see what I can find at the pull and pay. Maybe worth it to pick one up if it's not too much at the parts store.
Fri Jan 27, 2017 9:54 pm
They are expensive. I'd like to find a used one to test but those would be a rare find in a wrecking yard.
Fri Jan 27, 2017 11:05 pm
Sat Jan 28, 2017 12:45 am
Sat Jan 28, 2017 10:52 am
Sat Jan 28, 2017 10:53 am
32,409,614 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
