www.ColoradoClassicBroncos.com - View topic - Good set of 4.11 ring and pinnion dana 44 high pinion gear s
It is currently Fri Nov 01, 2024 12:29 am
Reply to topic  [ 6 posts ]
Post Good set of 4.11 ring and pinnion dana 44 high pinion gear s
Looking for a set of 4.11 gears for my full width axle swap dana 44, mabey if someone switched and still has the 4.11s available?
Thanks guys
Fri Jan 27, 2017 1:46 pm
Post Re: Good set of 4.11 ring and pinnion dana 44 high pinion ge
Sat Jan 28, 2017 7:58 am
Try Ron's, he seems to have real good package prices. I bought my SD gear & bearings from him, excellent service.
http://www.ronsmachiningservice.net/reverse-rotation/
Sat Jan 28, 2017 11:31 am
Would you ever buy an used set, or would this be a bad idea?
Sat Jan 28, 2017 4:02 pm
Sat Jan 28, 2017 4:32 pm
If you're patient, good deals are out there. My fronts are used, $50 and went in fine. My rear gears I found new in the box off craigslist with the rebuild kit for cheap.
Sat Jan 28, 2017 6:31 pm
Users browsing this forum: No registered users and 48 guests
32,737,061 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
