www.ColoradoClassicBroncos.com - View topic - Hydroboost on 76 bronco question
It is currently Tue Oct 01, 2024 11:34 am
Reply to topic  [ 16 posts ]
Post Hydroboost on 76 bronco question
I have everything pretty much figured out for my hydroboost swap on my 76 except where to put the inline proportion valve. Does it go after the stock brake proportion block, before it or replace it? I would think before to regulate the bias to the rear and have the "benefit" of the brake warning light?
Wed Feb 15, 2017 9:03 am
Post Re: Hydroboost on 76 bronco question
You shouldn't need another proportioning valve. '76-'77 had one. Prior years only had a distribution block.
Wed Feb 15, 2017 9:11 am
I guess I can run without one and use the stock block and see how it goes!
Wed Feb 15, 2017 1:14 pm
I used my stock H block with my hydroboost. I had chevy disk on my rear 60. it would lock up the rear first, but not super terrible.
Wed Feb 15, 2017 1:41 pm
i have the stock drums on the rear, was reading on CB.com that most people have to put a after market proportion valve to dial down the rear bias.
Wed Feb 15, 2017 4:51 pm
Or switch the front calipers to the t-bird calipers. That pulled my bias from the rear to the front. They fit the F150 brakes, not sure about the stock Bronco disks.
Wed Feb 15, 2017 4:55 pm
Wed Feb 15, 2017 7:45 pm
Schweat!
Wed Feb 15, 2017 8:18 pm
So I see most are using the Camero master cylinder, is this the best one? What about an aftermarket aluminum or others? Do I need to just find one with the right bore size and passenger side outlets?
Sat Feb 18, 2017 6:39 pm
I believe the 1978 camaro MC is the correct one.
Sat Feb 18, 2017 9:24 pm
Sun Feb 19, 2017 8:19 am
Ok will check it out thanks.
Sun Feb 19, 2017 9:54 am
There are 2 different ones available. one is for power brakes. Thats the one you want.
Sun Feb 19, 2017 8:04 pm
Mon Feb 20, 2017 9:38 am
I made all new lines.
Mon Feb 20, 2017 10:38 am
Mon Feb 20, 2017 10:39 am
32,411,376 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
