Full width axle swap 76 f150
Re: Full width axle swap 76 f150
Postby rooster » Tue Apr 04, 2017 12:27 pm
That would be awesome! How much would you charge for that?
rooster
Postby Justin » Tue Apr 04, 2017 2:46 pm
Nothing. Just bring it over with a tie rod end. Your other option is to drill a straight 7/8" hole and use a tapered sleeve.
Postby ZOSO » Tue Apr 04, 2017 2:50 pm
Justin wrote:I have it and can ream your knuckles.
As in you have my reamer?
Postby Justin » Tue Apr 04, 2017 2:54 pm
Yes, I have your reamer.
Postby rooster » Tue Apr 04, 2017 3:37 pm
Justin that would be awesome, do you think Friday or Saturday would work for you?
rooster
Postby Justin » Tue Apr 04, 2017 6:35 pm
I could do Friday after work or Saturday mid to late afternoon.
Postby rooster » Wed Apr 05, 2017 6:33 pm
Cool man I think either one will work for me, I will let you know.
Before I put this front axle back together I wanted to see what you guys think about my gear pattern check . Backlash is a little tight with a .005 to .006 reading.
This is the first gear set I've set up ,based on everything I've researched I think it's pretty close, but wanted to ask the experts!
These are also new gears, don't know if that matters or not
rooster
Postby Digger » Wed Apr 05, 2017 10:24 pm
Looks good from the pictures.
Postby rooster » Thu Apr 06, 2017 12:52 pm
I forgot to mention basically all my shims ended up being on the on the side pushing the ring gear away from the pinnion, do you think that this could result in not enough spline contact on the axle shaft the carrier is moved away from? I really hope I can get away with leaving it as I've had it apart like 7 times to get to where I'm at now
rooster
Postby rooster » Sun Apr 09, 2017 7:20 pm
Well I finally had some time to get my front axle all buttoned up, ARB installed, and everything torqed down. and I have to say it was a great learning experience, pinnion pre load is 21 inch pounds and my back lash is now at .007 and carrier bearing pre load is good to so imma call it good. I have the older style ARB but upon inspection everything looked to be in great shape including the bearings so I just reinstalled it as it was (hopefully it'll be okay) anybody know if getting the marking compound off completely is super important.?
rooster
Postby Jesus_man » Mon Apr 10, 2017 6:50 am
Good work! The bronco has two great styles of axles to learn on, the 9" being the easiest and the D44 being a fair bit more difficult!
As to the marking compound - you could spray it off with brake cleaner or the like, but I don't think there is a need.
You have an HD diff cover for that axle?
Postby rooster » Mon Apr 10, 2017 7:23 am
Thanks! Ya I'm glad I decided to try it, the 9" already has the right gears so I'll just swap the whole 3rd member into the full width housing.
And no all I have is the stock one...
rooster
Postby Jesus_man » Mon Apr 10, 2017 8:15 am
Makes sense to put one on now. I like my GLO (Great Lakes Offroad) cover.
Looks like you can now add a drain plug!
http://www.greatlakeoffroad.com/GLO-Dan ... Cover.html
Postby rooster » Mon Apr 10, 2017 8:51 am
Ya your probably right , that thing looks awesome! Want to do this right the first time... But cheaply as possible:) if anybody has a heavy duty cover they want to sell id be interested
I also really like this one from sexton...
http://sextonoffroad.com/i-7543152-d44- ... cover.html
rooster
Postby Jesus_man » Mon Apr 10, 2017 9:20 am
That looks really nice, but you lose the ability to weld to it if you ever decide that is a good place to weld hydraulic ram mounting tabs. I was able to mount my ram without welding to the diff cover, but it is a popular place to mount one.
Postby rooster » Mon Apr 10, 2017 10:02 am
Good point with it being cast iron, the ram doesn't stress the cover bolts too much? I would definitely like to add a ram some day
rooster
Postby Jesus_man » Mon Apr 10, 2017 11:04 am
I much prefer NOT to weld to the diff cover for a ram mount because the back and forth pulling loosens the bolts overtime and you will likely be leaking before you snap bolts. But sometimes the geometry dictates where those brackets go.
Postby rooster » Mon Apr 10, 2017 12:15 pm
Ya you would think that would be problematic after some time
Anybody have the sexton dana 44 'bronco' script cover?
If so how do you like it and does it stick out considerably father than stock?
rooster
Postby rooster » Thu Apr 13, 2017 8:45 pm
Had some time to work on the bronco today, decided to get the duff offset spring towers, so I cut the old ones off. Also decided to get a new track bar bracket from ruffstuff. It will definitely need to be cut down but it will work after that I think. Hopefully cause I cut the stock one off
rooster
Postby rooster » Sun Apr 23, 2017 1:10 pm
Got some time this weekend to get some work done to the front axle, basically ready to be installed under the truck,
rooster
Postby rooster » Sun Apr 23, 2017 1:52 pm
Do you guys think that setting toe in would be easier with the axle out vs in?
Also big thanks to Justin for reaming out my knuckles and pitman arm for chevy tie rod conversion
rooster
Postby Digger » Sun Apr 23, 2017 3:46 pm
Get it close with the axle out, but check it once installed.
Postby cravenbronco » Sun Apr 23, 2017 6:29 pm
Stupid question. How are you going to lift the front end ?
cravenbronco
Postby Justin » Sun Apr 23, 2017 6:35 pm
Welcome. What Digger said.
Postby rooster » Sun Apr 23, 2017 7:17 pm
I have the front supported by the tallest jack stands I could get my hands on, I was able to lower the old axle down far enough to take the pressure of the springs , so my plan was to roll the new axle underneath with two roll around floor Jacks ,one underneath each axle wedge.and then once I got it close I would jack them both up enough to put a small jack stand on each side or something to support the axle high enough to bolt the radius arms on.
...at least that was my plan... I also thought about putting the tires back on and rolling it underneath like that but it would be a lot more difficult to get around the jack stands that are holding up my frame that way
rooster
Postby Justin » Sun Apr 23, 2017 8:35 pm
I've got a spare POS harbor freight trans jack the worked great to move mine around. Not sure if you ever get down this way, but you're welcome to borrow it. Dragging it also works. I was able to loft one end at a time and then have a helper put a jack stand under it.
Postby rooster » Mon Apr 24, 2017 6:18 am
Hey that's a great idea! My dad actually has a really nice tranny jack but I appreciate the offer! Also do you think if I decide to keep the axle in the stock location it would be a good idea to still move the coil towers 1" forward, or would this cause excessive coil bow? I figured if I do it this way it will make moving the axle easier in the future should I feel the need
rooster
rooster
Postby Jesus_man » Mon Apr 24, 2017 6:55 am
I would move the axle as far forward as you can now. It won't get easier down the road. My memory is failing right now, but I think mine is forward either 2" or 3". Mine is about as far forward as you can go without moving the steering box.
Postby Gunnibronco » Mon Apr 24, 2017 10:50 am
I've moved mine forward almost 2", but had to push the new 4x4x2 box forward, right up against the front body mount (it would also be in my core support, if I still had one). I won't comment on if you should do it now, I clearly have bad judgement in that department. But you'll be moving your radius arm mounts, and shock mounts, as well as your track bar to get it all forward (now or in the future). Use your best judgement.
