It is currently Sat Nov 23, 2024 8:51 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 72, 73, 74, 75, 76, 77, 78 ... 89  Next
Wed Mar 29, 2017 12:32 am
Got the cage finished this weekend and everything put back together.... icon biggin
Tue Apr 11, 2017 7:09 am
Very nicely done thumbs up
Tue Apr 11, 2017 12:06 pm
Tue Apr 11, 2017 12:28 pm
with nice rockers!
Tue Apr 11, 2017 1:31 pm
Tue Apr 11, 2017 1:37 pm
Tue Apr 11, 2017 1:40 pm
thumbs up flipoff lmao
Tue Apr 11, 2017 4:06 pm
Flipped my battery cables around to get ready for summer...
Thu Apr 20, 2017 7:28 pm
Ordered an intank kit for the fuel pump from sunset fab. Will have to order a pump and a hydramat sock for it. Plan to weld in the shock hoops this weekend and measure again for shocks. Get that order out to bilstein. Then pull the radiator and balancer and get that all re done again.
Fri Apr 21, 2017 5:16 pm
Fri Apr 21, 2017 7:02 pm
Ordered my 14in short body 7100's with custom valving from Lee at raceshock. Should get those in 2 weeks.
Thu Apr 27, 2017 8:25 am
Thu Apr 27, 2017 10:46 am
Testing a new part.
Fri Apr 28, 2017 9:54 am
What is the new one out of? What are the differences in specs?
Fri Apr 28, 2017 10:38 am
Fri Apr 28, 2017 2:23 pm
Want. It'd wake my ram up.
Fri Apr 28, 2017 9:09 pm
Sat Apr 29, 2017 6:54 am
This project took a lot longer than I was hoping. Improvisation was my word of the day. I think it turned out fairly decent considering it really never wanted to fit the entire day.
Sun Apr 30, 2017 7:25 pm
Images: 11
Started a new project today. This should be nice.Image
Sat May 13, 2017 5:56 pm
Images: 11
Installed and about to do plumbing. Really looking forward to this.Image
Tue May 16, 2017 8:54 pm
Brought her home!!!
Then I have taken her out for a spin to town a time or two! I need to check to see if any of my indicator lights work as I suspect they don't, but it's good to be driving the ole girl again!!!
Mon May 29, 2017 6:54 am
That has to feel good !
Mon May 29, 2017 7:11 am
Finally got my 14" 7100 short bodies. Custom valved at 345/135D.
Wed May 31, 2017 7:37 am
Finally got a minute to work on the Bronco
Replaced the stock spare tire mounting hardware with a plate I got from battlement fab.
Sat Jun 03, 2017 1:40 pm
What a long hot day in the garage. Good news is I'm 95% done. Should fire up mid morning.
Sat Jun 10, 2017 10:43 pm
Sat Jun 10, 2017 10:54 pm
I was finally able to get the ugly farmers bumper off the front end of the 66 halfcab. Now all I have to do is box the frame and where my new to me snow plow mounts up. Like usual I'm sure it will turn into a bigger list. But no more ugly farmers bumper.
Sun Jun 11, 2017 5:32 am
I installed the wiring for the trailer I bought from Digger. I still need to figure out a power wire to run the trailer battery and refrigerator. Would like to figure a way to run switched power so if I forget to disconnect for a long period of time it won't drain my battery.
I also applied a rubberized liquid roof to the trailer to fix about 40 cracks and dents from the hail storm that hit a month or so ago.
Fri Jun 16, 2017 7:49 pm
Glad to see you're getting the roof fixed.
Here are a couple examples of automatic relays I was talking about:
Blue Sea Systems 7611:
Sure Power 1315A
Cole Hersee 48530
WirthCo 20092
Of course you can wire in a standard 30amp relay as well and drive it off an ignition feed. Here is a diagram for a dual battery setup. In this case, the 2nd battery is on the trailer with its own fuse already. You would fuse at 20-30 amps and wire with 12ga.
Fri Jun 16, 2017 9:45 pm
32,982,994 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
