horseplay wrote:A popping fuse will be a power short to ground or circuit overload. Check your wiring and make sure your cage is free inside the boxö
B.O.B. wrote:Had a buddy with a 3d printer make a small spacer between the housing and the motor to clearance the cage. Should work like a charm now. Got my reseal kit for Christmas so just need to do that and should be golden.
The core seems good but do you all think I should replace?
