rt9 wrote:Thanks guys - just got home and checked spark. The truck still wouldn't start, but I do have spark. (bought one of those fancy little spark testers - cool)
I played around with it a while, checking all the cable connections, still no luck. Rolled it back down the driveway a bit so I can get the Bronco out tomorrow morning, and sure as s*#t it started then. I did hear the fuel pump give a little short growl this time. Tried it again about 10 minutes later, heard the fuel pump run about 1-2 seconds and she started right up.
Fuel pump? Relay? Controller? Gremlins?
Jesus_man wrote:My thought was relay. For somereason, some of them get picky if they are not upright with the connector facing down. Find your relay and see if it's free to move around.
Justin wrote:You might check the thread on your rail. I just ordered the stuff to add a gauge to mine. Gauge was 1/8 npt and needed a 1/16 npt adapter, but I'm running later model stuff than Eck.
