My Engine rebuild
Re: My Engine rebuild
Postby Jesus_man » Sun Apr 30, 2017 6:48 pm
I actually don't know what heads they are... how bad is that?
What a generous club! I'll keep you all posted!
I have gt40 intake. Are the heads a plug and play operation? I'm inclined to do what cheapest at this point... I gotta stop the wallet bleed!
Postby cpldavis37 » Sun Apr 30, 2017 8:55 pm
If your motor is stock then E7s should be ok. One of my sets have crane roller rockers, but maybe they all did, I have no idea.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Mon May 01, 2017 9:34 am
The stop leak will arrive at my dad's tuesday. Once he has it, I should have a verdict in about 15 minutes if he has success...
BTW - can everyone see the start-up video? I never know if Google allows others to view or not.
Postby Eck » Mon May 01, 2017 9:39 am
Good luck-- I too have the old E7 heads-- you are free to them as well (I will even throw in a free 3 spd with it!).
The video worked for me. I dig that over the tire step stool. I have never seen anything like that!
Postby Jesus_man » Mon May 01, 2017 10:39 am
Eck wrote:I have never seen anything like that!
That thing was a huge help!! Your knees and hamstrings take a beating if you are standing on the tire and this stool saved us there!!! I want one now!!
Postby Jesus_man » Wed May 03, 2017 7:44 am
BTW - here is a similar tire step to what we used. It matches the same dimensions:
https://mobiledistributorsupply.com/249 ... aQodIOUKaw
Additionally, my dad calls the local Napa, "Mañana auto parts" and it holds true. Irontite makes three different types of coolant stop leak and two of the three came in yesterday, just not the one I wanted!!! Perhaps today!
Postby Jesus_man » Thu May 04, 2017 10:30 am
I am thinking I need to be picking up a set of heads for "just in case". So I am looking to see of the ones offered, which I should try to pickup.
cpldavis37's has some upgrades that might be nice... But it may just come down to geographics, who's local to someone I can get them from.
Postby phyler » Thu May 04, 2017 10:54 am
Jesus_man wrote:I am thinking I need to be picking up a set of heads for "just in case". So I am looking to see of the ones offered, which I should try to pickup.
Cpldavis37 isn't that far from me. Happy to store them for you if needed. I also get down to Denver regularly if they need to be dropped off somewhere along I-25.
CCB Admin
Postby Jesus_man » Thu May 04, 2017 2:28 pm
Just FYI, this is the cracked head after the irontite all weather stop leak:
under black light
I'd love your input on this, and also what you think might have happened. I talked to the machine shop and they say it's unlikely the head was cracked when it left their shop as they use some process to check it for cracks...
Postby cpldavis37 » Fri May 05, 2017 7:37 am
Just let me know if you want them. No hurry they are just sitting in my garage.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Fri May 05, 2017 7:52 am
cpldavis37 wrote:Just let me know if you want them. No hurry they are just sitting in my garage.
I am certainly leaning that way, so please put my name on them and if you happen to find an easy way to get them to 38th and Federal, please let me know. I'll be in CO on the 18th-24th, but I actually have no plans to be in Denver. Furthest North will Pueblo. However, I am just hoping I can stop the leak internally and externally and run these for a long time! But I think it'd be wise to have a backup set just in case!
Postby Rox Crusher » Fri May 05, 2017 10:28 am
Jesus_man wrote: I can stop the leak internally and externally and run these for a long time! But I think it'd be wise to have a backup set just in case!
I don't know the first thing about that miracle potion you used.........but I would be impressed if it works as a long term solution.
Postby Justin » Fri May 05, 2017 7:54 pm
I'm going to Pueblo on the 19th and can transport them to 38th and federal.
Postby Jesus_man » Sat May 06, 2017 6:08 am
Justin if you and TJ can easily make the connection, that would be awesome. If not don't sweat it.
What's your schedule in Pueblo? I'll see if it lines up with my in-laws.
Otherwise wheatridge is fine and I'll get them at a later date.
Postby Justin » Sat May 06, 2017 7:27 am
I usually land at work on the south side of town around 9 and head back to denver between 2 and 3.
Postby ZOSO » Sat May 06, 2017 8:18 pm
Just grind on it to clean it up and slap some JB weld on it.....
Postby Jesus_man » Sun May 07, 2017 9:23 am
I think I'll pull the header off and see where that crack goes. I may try to carve a small valley out and JB weld it if I think that will be successful.
Postby Jesus_man » Sun May 07, 2017 9:37 am
Justin wrote:I'm going to Pueblo on the 19th and can transport them to 38th and federal.
I'll see if my in-laws will be in Pueblo on the 19th. I might have another avenue if that doesn't pan out as my cousin works at Kenworth there on the northside of Pueblo.
Otherwise, 38th and Fed will work until I can get them here.
Postby cpldavis37 » Sun May 07, 2017 3:40 pm
I can pull them off and meet up with Justin. I'll pm Justin and get his address
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Mon May 08, 2017 5:08 am
TJ - thanks man!! I'd be happy to pay for something...you let me know.
Justin - Would it be better for you to have my inlaws meet you or to drop them off at Kenworth? And same to you, if you need some gas/beer money...
Postby Justin » Mon May 08, 2017 7:06 pm
My company pays my mileage, no $$ needed. Where's kenwortg? If they can bring them, that'd be ideal. I'm just off i25.
Postby Jesus_man » Mon May 08, 2017 7:18 pm
Justin wrote:My company pays my mileage, no $$ needed. Where's kenwortg? If they can bring them, that'd be ideal. I'm just off i25.
Kenworth is just off I-25 on the Northside. Or my inlaws can meet you wherever is easy for you. They would be traveling from the south.
Postby Justin » Mon May 08, 2017 7:24 pm
I'll be on the south side of town, so my work sounds like it's better for all involved.
Postby Jesus_man » Tue May 16, 2017 6:49 am
Do we have any updates on the acquisition of these heads? If it doesn't work this time there is a backup location.
Postby cpldavis37 » Tue May 16, 2017 6:53 pm
I need to meet up with Justin or I can deliver them somewhere I just need to know where.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Justin » Tue May 16, 2017 7:41 pm
I may be delaying my Pueblo run till next week depending on how this storm shapes up. Not really interested in turning a 2 hour drive into a 4 hour one.
Postby Jesus_man » Wed May 17, 2017 4:10 am
That's fine. My only push is that I'll be in CO for about a week starting thursday the 18th and have the ability to bring them home. But it's not critical so if that doesn't work. At that point I only need to get them to Federal and 38th at your convenience. From there I can have family get them to where they need to be.
Postby Justin » Thu May 18, 2017 9:19 pm
Definitely pushing the Pueblo run back to next week. Not sure yet which day it'll happen.
Postby Jesus_man » Fri Jun 16, 2017 9:04 am
cpldavis37 wrote:I need to meet up with Justin or I can deliver them somewhere I just need to know where.
It is more convenient for you to meet with Justin or do you ever drive near 38th and Federal?
Postby Justin » Sun Jun 18, 2017 7:38 pm
I'll be in Thornton Monday and Wednesday this week. I'll be in Pueblo on Friday
