Pitman arm install question.
Postby laffycaffi » Sun May 07, 2017 7:06 am
Hey, wondering if you have any tips with reinstalling Pittman arms. When I put the nut on, the entire part spins. So.the nut isn't actually threading on. Not sure if that makes sense. Also, all of my boots got destroyed during the uninstall. I assume I should buy some new boots somewhere?
laffycaffi
Re: Pitman arm install question.
Postby Digger » Sun May 07, 2017 2:32 pm
I believe you are referring to the tie rod ends.
yes they can spin. The trick is to put some pressure on the tie rod so the tapered section seats tight in the knuckle or pitman man. That will stop the rotation.
As for boots, if you are using a brand like Moog or similar, it is usually possible to find replacement boots online. Try to avoid using a pickle fork for removal, they tend to destroy boots. A proper ball joint tool works much better.
Postby TOOLMAN » Mon May 08, 2017 6:30 am
You can get red polyurethane boots at Autozone in the performance suspension section....I've had to use them before.
TOOLMAN
Postby laffycaffi » Mon May 08, 2017 8:33 am
Good stuff. Thanks everyone.
laffycaffi
Postby landshark » Mon May 08, 2017 9:31 pm
i have used a jack with a 4x4 on it to put pressure on the bottom of the Rod end to stop the spinning.
Postby laffycaffi » Mon May 08, 2017 9:56 pm
landshark wrote:i have used a jack with a 4x4 on it to put pressure on the bottom of the Rod end to stop the spinning.
That's actually exactly what I did, except I used a piece of firewood. ;)
laffycaffi
