Harmonic balancer, on all the way?
Postby cpldavis37 » Thu May 11, 2017 9:26 pm
I took some pictures, it looks like it should go on further. The pulley lines up with the water pump pulley. What do the experts say?
TJ
F. Scott Fitzgerald
cpldavis37
Re: Harmonic balancer, on all the way?
Postby Kinder » Fri May 12, 2017 10:43 am
If it lines up then you should be good, I'd check it with the accessory pulleys and call it done.
Postby Viperwolf1 » Fri May 12, 2017 3:00 pm
Pics don't work for me.
Postby D&D72 » Fri May 12, 2017 6:50 pm
Me either. I think that needs to go in more. doubt your crank sensor would line up.
D&D72
Postby cpldavis37 » Sat May 13, 2017 11:53 am
Phil can you not see the pics or does it not look right?
TJ
F. Scott Fitzgerald
cpldavis37
Postby Viperwolf1 » Sat May 13, 2017 3:00 pm
Can't see the pics on my phone.
