[phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/viewtopic.php on line 1644: sizeof(): Parameter must be an array or an object that implements Countable [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4796: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4797: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) [phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4798: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3855) www.ColoradoClassicBroncos.com - View topic - What wires under hood power the windshield washer pump?
Author
Message
ClayJ
I recently put one of the dual tanks under the hood, with radiator overflow and windshield washer w/ integrated pump. Now I need to power the washer pump, but I have no idea which wires long ago used to power the original pump.
Are the wires drivers side or passenger side? Up near the front or back by the firewall?
My bronco is a 1970
Mon Oct 25, 2010 11:51 am
airbur
Re: What wires under hood power the windshield washer pump?
Looks like a green/black and brown that come right off the harness at the driver's side headlight. I can snap a pic if that helps.
