Brake lights not working
Postby Eck » Thu May 25, 2017 8:21 pm
As the post says, brake lights aren't working.
Fuses are ok
Emergency flashers and turn signals working
Running lights working
Bulbs not burnt out
Connector at brake pedal on
What can it be?
Re: Brake lights not working
Postby Viperwolf1 » Thu May 25, 2017 9:17 pm
It could be the brake light switch. Test it.
Postby Digger » Thu May 25, 2017 9:18 pm
Brake light switch. You could check by connecting the two leads at the brake light switch to each other.
Postby Eck » Thu May 25, 2017 9:24 pm
Thanks- will jump it in the morning.
Postby Eck » Fri May 26, 2017 9:25 am
So the brake light switch itself is working. I also had gotten a new one to try that and it's working. Both of them only work when I engage them by hand. Once I put it on the pedal assembly, I get nothing. I've adjusted the brake pedal pushrod out as far as it will go to take all slip out of the pedal and I still can't get it to work. Any ideas?
Postby Kinder » Fri May 26, 2017 11:27 am
If everything else is good then your switch isn't making contact, try a very thin shim between the contact plate and the switch, say the thickness of a old school fuse lid.
Postby Eck » Fri May 26, 2017 11:34 am
I shortened the distance by wrapping the end of the shaft in some electrical tape and it now works. Might mess with a better MacGuyver fix down the road.
Postby BOBS 2 68S » Sat May 27, 2017 4:44 am
I had a short in the turn signal wiring after replacing the turn signal canceler. Fixed the short and got my brake lights back.
BOBS 2 68S
Postby landshark » Sat May 27, 2017 9:18 am
I had the same issue, ended up spot welding a really thin piece of metal to the brake light switch plate in the red one.
Postby Eck » Sat May 27, 2017 9:23 am
landshark wrote:I had the same issue, ended up spot welding a really thin piece of metal to the brake light switch plate in the red one.
Yah- thinking I'll add a thin layer either to the switch plate or the rod end. Probably just JB Weld it since it's not structural.
Postby Viperwolf1 » Sat May 27, 2017 9:52 am
You just need to bend the plate in the switch slightly.
Postby Eck » Thu Jun 01, 2017 11:57 am
So I tried to see if I could bend the plate on the switch and I couldn't really figure out how to do it as its the thickest part on the switch and so I had nothing to really pry against. It proved much easier to just take the brake pedal rod off and add a bead of weld to the end of it to thicken it up. The tape was definitely a temporary fix as I realized I had no brake lights again on my way home from throwing around Wilma. Bead of weld did the trick and I assume will be a permanent fix...
