Justin wrote:That's a big cooler for that application, and not the spot I'd put it in. I'd replace and relocate. I've got a largeish cooler you can have that'd work great mounted to the front of a radiator.
pgilbeau wrote:I would replace that and move it, I doubt that it gets much air in that location. I run a cooler for my P/S and its located in front of my radiator. You might want to keep future expansion in mind since there is the potential for running more systems off the P/S. The biggest reason I run a larger cooler is because along with the P/S I am running a PSC external reservoir and hydro-boost.
Dirtheadz wrote:bigger the better in my opinion. Essentially your power steering system is a down scaled hydraulic system. More volume = less heat. Slow speed wheeling, getting airflow is a chore & heat is the enemy. My last bronco (hydro boost & 37's) I ran the biggest trans cooler for my power steering I could get locally. But heck what do I know, I don't even own a Bronco anymore.
