Map light wiring
Map light wiring
Postby Jesus_man » Wed Jul 05, 2017 2:17 pm
I came across this mirror in a box of Bronco stuff recently and decided I should put it in my bronco, but I am hoping someone with some better know-how can help me with how to wire it.
I just replaced both bulbs with LED for lower power drain as well as brightness. Hard to see in the pic, but I tested it against the incandescent bulb.
Here's the wiring arrangement; white, orange, black:
I have electric wipers...can I tap into that for power?? You can see the built-in switches.
Re: Map light wiring
Postby plumbdoctor » Wed Jul 05, 2017 7:45 pm
Might already be power there if it once had the wiper linkage cover light, our 74 did.....did73's?
plumbdoctor
Postby Jesus_man » Wed Jul 05, 2017 7:50 pm
hmm, this bronco never had a fancy wiper motor cover in my ownership, but there would certainly be evidence if there is a connector up there!! I'll investigate.
Postby plumbdoctor » Wed Jul 05, 2017 7:52 pm
Single wire is what the turd had...no connectorother side grounded to frame
Black wire w/ dark blue stripe is what we have
plumbdoctor
Postby Eck » Wed Jul 05, 2017 8:44 pm
The orange wire is 12V, the black is ground, and the white is switched ground. This was what I could find online. I think you will not use the white wire as it probably had something to do with the lights turning on when the door to the vehicle opens. The red wire for your electric wiper motor should be power. Seems fairly simple...
Postby Jesus_man » Thu Jul 06, 2017 5:29 am
Awesome! Thanks for checking on that for me. I should be able to test that theory on the battery again correct? IN the above pic (I hope you can see that), I have the orange to the neg terminal and the white to the positive. That seemed to allow me to turn the lights on with the switch. There was another combo that turned them on with the switches off, so that must be for doors open...
I did check, and there is indeed a black wire with blue stripe up there, just cut off. So I'll test it for power!
