rt9 wrote:I think your rubber windshield frame seal is backwards. Bronco Hut told me the bead goes toward the rear. This will help with the gap at the top. Not sure, but that's what Dana told me.
Gunnibronco wrote:rt9 wrote:I think your rubber windshield frame seal is backwards. Bronco Hut told me the bead goes toward the rear. This will help with the gap at the top. Not sure, but that's what Dana told me.
Is there even a seal there? I don't see one.
You have some funky gaps going on, take this slow and carefully. I'm having trouble putting my thoughts into words. The gaps around the door window frame look like trouble, like the top isn't sitting right. If you fix one gap, you'll make another worse.
Give me a ring, I'd like to discuss some things to look for before moving things around. I had some weird damage on my truck that when I found it made the door openings easier to manage. If you don't have my number, let me know & I'll message it to you.
rt9 wrote:Is your windshield frame welded in place or bolted? Not sure when they changed to welding them in place.
Gunnibronco wrote:37" dead on both sides of my 72, which has pretty darn good gaps.
Strike2 wrote:I just removed my rear tire carrier this week end, once I'm back home I will take a look inside and see if I can tell how its attached. thinking it spot welded?
mickphatmac wrote:Just a guess but before you tear that rear corner off all together and try and straighten everything associated with it, maybe take a 4x4 and put it on a jack and prop it up under the Top horn of the tire carrier and go to town? But, if the metal came apart once, it will do it again...refer to the 1st part of my post :(
I haven't done this, just thinking out loud.
phyler wrote:Strike2 wrote: I'm leaning towards building a stealth bumper and building the tire rack into it (like I saw on CB.com). That will fix the issue of the spare tire causing the housing to pull away.
Only thanks to screws and ratchet straps. It still isn't as nice as I would have liked but it is only off by about 1/16". Hoping that the seam sealer will help advert my eyes from it.landshark wrote:looking great! the rear quarter lined up nice
Had to think about that for a moment. I'll see what I have that could act like a shim for that spot.Gunnibronco wrote:That sucks.
You can try putting a shim between the hinge and the door post, on the inside bolt. That should push the door hinge forward a bit.
