Stock pitman arm
Stock pitman arm
Postby crawlercreations » Sun Aug 13, 2017 6:35 pm
Before I order a used arm from wildhorses I figure I'll ask here. I'm looking for a stock pitman arm that'll work on a '78 or '79 4x4x2 gearbox(I can't remember if the stock bronco arm fits that box) but I need one for my uncle's truck. Let me know if you can help me out and how much you want please!
Pictures of truck attached. It's 1963 I put a 522 stroker in, zf5 speed and now I'm in the middle of full new suspension (just leaf springs on full custom mounts), Sterling 10.5 rear end, Dana 60 front end, 4 wheel power disc brakes front and rear, power steering, and about 4" of lift on 35's.
Re: Stock pitman arm
Postby Jesus_man » Sun Aug 13, 2017 8:08 pm
Cool truck, but that's a lot of beef for a street cruiser!
Postby crawlercreations » Sun Aug 13, 2017 8:24 pm
Jesus_man wrote:Cool truck, but that's a lot of beef for a street cruiser!
Build it once is the idea. It is a 3/4 ton truck and he does haul heavy stuff in the bed and plans to tow his SAS full-size bronco on 37s with it so beef will be needed. The engine is just for fun really though. Happy to say I built that for him too. Mild cam has it around 600 h.p. and 600 lb.ft. of torque.
Postby Kinder » Mon Aug 14, 2017 5:16 am
Very nice truck, I believe the pitman arms are the same, I've given so many away I might be out, but I'll check my pile.
Postby cravenbronco » Mon Aug 14, 2017 5:20 am
Will have to check
cravenbronco
Stock pitman arm
Postby landshark » Mon Aug 14, 2017 6:24 am
I might have one as well. Will check.
Edit: just checked and do not have one here, might be in storage.
Postby Justin » Mon Aug 14, 2017 11:51 am
Pittman arm from a bronco Will fit 4x4x2. That's what I'm running on mine.
Postby crawlercreations » Mon Aug 14, 2017 5:18 pm
Justin wrote:Pittman arm from a bronco Will fit 4x4x2. That's what I'm running on mine.
Thanks for the info!
If no one has one by tomorrow morning I'll have to order one from a bronco vendor asap.
Postby plumbdoctor » Mon Aug 14, 2017 9:03 pm
I have one here, but it has the joint on the end not a hole.....probably not what you need?
plumbdoctor
Postby crawlercreations » Tue Aug 15, 2017 5:04 am
plumbdoctor wrote:I have one here, but it has the joint on the end not a hole.....probably not what you need?
Correct, not what I need.
Postby Kinder » Tue Aug 15, 2017 10:20 am
No luck here, only a drop arm.
Postby mickphatmac » Tue Aug 15, 2017 11:19 am
kinder wrote:No luck here, only a drop arm.
I just might be looking for a Drop Pit...
and I have a stock Pitman arm for Crawler!
Postby Kinder » Thu Aug 17, 2017 6:17 am
Come and get it!
Return to Bronco Parts Wanted
