ZOSO wrote:I should have left it all alone. But instead I wanted to make it right. Ever since I did the explorer swap I've had a small engine vibration. So I pulled the balancer last weekend and had it "matched" to the original. Well now it shakes even worse. So out comes the motor now so I can have the whole bottom end redone. I'm getting tired of this thing.
ZOSO wrote:Eck can you take your bad luck back. Sitting on the side of the road with a knocking engine again. Sounds like valve train again.
You got help coming? If not, if you're on the north end, feel free to reach out.ZOSO wrote:Eck can you take your bad luck back. Sitting on the side of the road with a knocking engine again. Sounds like valve train again.
