Time to switch oil?
Time to switch oil?
Postby Eck » Tue Sep 19, 2017 6:48 pm
So when I got my engine rebuilt, the engine builder recommended VR1 10w-50 Racing Oil because of the zinc content. I have since changed the cam from a flat tappet to a roller cam with a roller lifter kit.
So should I change to standard motor oil now? I've got about 5000 miles on the engine since the rebuild. What should I be using? For what it's worth, I've been using the Baldwin filters.
Re: Time to switch oil?
Postby Jesus_man » Wed Sep 20, 2017 7:43 am
I'd stick with an oil with a high zinc content. It can't hurt. My machine shop recommended Rotella T after I have used up all my racing oil.
The alternative is to use an additive. BG MOA for instance.
Postby ZOSO » Wed Sep 20, 2017 8:35 am
Rotella changed their formula and cut back on the zinc a lot. I used to run just regular Valvoline. Now I run Amsoil ZRod oil. Flat tappet or not high zinc is good to have.
Postby Digger » Wed Sep 20, 2017 10:30 pm
Right or wrong I'm running plain ole Valvoline 5W-30 with a 1994 block and roller cam.
Postby 347bronco » Fri Sep 22, 2017 4:33 pm
I run 10w -40 Lucas Hot Rod and classic oil. High zinc content only reason not to use high zinc oil is if you have a catalictic convertor. Shell has changed formula on Rotella less zinc .
347bronco
Postby Viperwolf1 » Fri Sep 22, 2017 7:03 pm
Digger wrote:Right or wrong I'm running plain ole Valvoline 5W-30 with a 1994 block and roller cam.
Same here.
Postby Jesus_man » Mon Nov 06, 2017 9:20 am
Same here.
I assume "Plain ole" means conventional? Not Full Syn. or Max Life? It's oil change time again for me.
