Pitman Arm options
Pitman Arm options
Postby landshark » Mon Oct 30, 2017 8:23 am
I am looking at options to swap out a pitman arm on my 4x4x2 box to gain a little distance from the drag link and lower link at compression. - I don't know what or if I have options but would love to find a drag link that is slightly shorter, even 1/4 or less. I can take some measurements tonight if need be. Thanks!
Re: Pitman Arm options
Postby Jesus_man » Mon Oct 30, 2017 9:49 am
Pictures would be helpful. So you say there is a potential interference between the pitman arm and the Tie-rod at compression? Can you clock your pitman arm to help?
Postby landshark » Mon Oct 30, 2017 10:17 am
Jesus_man wrote:Pictures would be helpful. So you say there is a potential interference between the pitman arm and the Tie-rod at compression? Can you clock your pitman arm to help?
i moved the axle forward about 3/4 - 1" two years ago - and while i think iam close to being ok, the DOM tubing on the drag link slightly scrapes the tie rod DOM at certain angles. I don't see how I could clock the pitman arm as that would limit my turning - and the hole in the pitman arm is tapered. i will grab a pic here as soon as i can
Here is one image - not great but gives you an idea of what iam talking about. This is with the drivers side at almost full compression.
Postby Jesus_man » Mon Oct 30, 2017 10:57 am
I was just thinking if you could clock it one tooth, that may be just enough to gain the clearance you need. But I do think that some of them you cannot clock because they have alignment splines. However, it is all in how the wheels are turned. A turn in any direction will help open up that gap.
How much of an interference is it? Just a scrape? I wouldn't worry about it. Even if it's a hard rub, I wouldn't be concerned. If it's trying to bend one or the other, then you could grind flat spots at those sections and repaint. I doubt you'd grind away enough to worry about strength issues.
Perhaps there is a slightly shorter pitman arm out there as well? Is that a drop arm? Maybe a flat one would be better?
Do you think at full compression that the tie-rod DOM will hit the joint at the pitman arm?
Postby landshark » Mon Oct 30, 2017 12:02 pm
Jesus_man wrote:I was just thinking if you could clock it one tooth, that may be just enough to gain the clearance you need. But I do think that some of them you cannot clock because they have alignment splines. However, it is all in how the wheels are turned. A turn in any direction will help open up that gap.
I thought about grinding, might end up doing that.
No other interference, checked full compresion and full droop lock to lock. I was hoping there was a slightly shorter pitman arm. Bonus if it is slight flatter - current arm is not a drop.
Postby Viperwolf1 » Tue Oct 31, 2017 6:36 am
The manual steering arms are slightly shorter but also less beefy.
Postby landshark » Tue Oct 31, 2017 8:20 am
Viperwolf1 wrote:The manual steering arms are slightly shorter but also less beefy.
might have to compare, beef may not matter too much as its probably enough for what I do.
Postby Viperwolf1 » Tue Oct 31, 2017 9:20 am
Astro arms are also short and completely flat.
