It is currently Mon May 13, 2024 9:20 pm
Reply to topic  [ 2657 posts ]  Go to page Previous  1 ... 74, 75, 76, 77, 78, 79, 80 ... 89  Next
Sun Oct 08, 2017 8:47 pm
Mon Oct 09, 2017 6:28 am
Big thanks to Phil for helping me with this project !
Yesterday I finished installing my ARB twin compressor system.
We relocated it from underneath the truck to the under-side of the rear seat. We made some brackets and welded them to seat frame and mounted the compressor to the bracket.
We also mounted a big ass air tank where the auxiliary fuel tank normally resides. 10" diameter by 30" long.
Unfortunately, after all that work, I found out that one of the compressors isn't working so I have to remove it for repair / replacelement.
Mon Oct 09, 2017 6:39 am
Mon Oct 09, 2017 8:02 am
Mon Oct 09, 2017 12:04 pm
Mon Oct 09, 2017 5:44 pm
$400 seems to be the going rate for those seats, a local mustang shop had a set a while back and that was the price.
Mon Oct 09, 2017 6:43 pm
Wed Oct 11, 2017 5:29 am
Still collecting parts for my 60-9 build and install. 3 link components procured during Columbus day sales. The single rod end is a 3/4"x3/4" for comparison.
Sat Oct 14, 2017 11:48 am
Installed the tailgate silencer kit from Wild Horses. Definitely makes a big difference.
Sun Oct 22, 2017 2:34 pm
Some beef showed up today! Gotta order a custom right side inner to get my wms where I want it but I pretty much have everything needed to build my 60-9 now! 35 spline inner and outer with super joints. Pictures are side by side with chromoly Bronco Dana 44 axles and super joint.
Tue Nov 14, 2017 3:50 pm
Will those still slide out of the knuckles? Beefy for sure!!
Tue Nov 14, 2017 3:55 pm
Tue Nov 14, 2017 3:58 pm
I suspect you'll have other issues if you do something to break those!
Tue Nov 14, 2017 4:14 pm
Just the numbers, 609, are magical!
Tue Nov 14, 2017 7:57 pm
Those are indeed some additional "beef" over the D/44. are you doing your own build thread process on them?
Wed Nov 15, 2017 7:25 am
Wed Nov 15, 2017 8:25 am
Nice, I'll be following that thread thumbs up
Wed Nov 15, 2017 9:27 am
More goodies for my Bronco today. Wheels! I also picked up some new knuckles that are machined for high steer arms and includes a high steer arm. Coming up soon is a hi9 3rd for the front. Project is a little delayed but I've also got a fabricated housing for the rear and strange nodular 3rd for it. 35 spline shafts will be on the way for it soon, too. Going to have spider 9s front and rear, all 35 spline. I can't wait!
Mon Dec 11, 2017 8:31 pm
That rim is crazy, what’s the engineering behind the design of the bead lock?
Mon Dec 11, 2017 9:14 pm
Mon Dec 11, 2017 9:37 pm
Enough wheeling and all those segments will be rashed. But I also think this comes down to manufacturing. To make a ring, you have to have a nice big piece which ends up with a lot of waste. This way, you don't!
I think you you should anodize two red, two white, & two blue...
Tue Dec 12, 2017 11:29 am
Ongoing Christmas for myself it seems!
Fri Jan 05, 2018 5:05 pm
drool!!!
I put a new signal flasher in today. Thinking the old one had an intermittent problem.
Fri Jan 05, 2018 6:22 pm
Fri Jan 05, 2018 7:07 pm
Final piece of the puzzle came in today!
Mon Jan 08, 2018 6:27 pm
Installed all new power steering, hydra-boost brakes and collapsible steering shaft.
HOLY C&%P! those brakes are amazing.
I have been driving a Bronco for almost 40 years and I will have relearn how to drive it with all the power assist .
Tue Jan 09, 2018 5:34 am
Awesome upgrades!! I am so tempted to do hydroboost, but for now, it's a luxury and there are things before it.
Tue Jan 09, 2018 11:26 am
Today I relocated my power steering reservoir from the firewall to the power steering pump bracket.
The pump was starving for fluid under certain conditions, especially if the Bronco was nose up.
I still want to get it up a bit higher to improve the return flow from the reservoir to the pump but it is already working better then previous arrangement.
Sun Jan 14, 2018 9:20 pm
That's a great idea. I ended up putting an extension plate on my inner fender and mounting my res on that. I'll have to look again, but I don't think I can do what you did as I believe my York resides there. Although...there are 4 threaded holes in the york...
Mon Jan 15, 2018 7:53 am
28,899,716 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
