www.ColoradoClassicBroncos.com - View topic - Help ID this Master Cyl. please!
It is currently Fri Nov 22, 2024 4:19 pm
Reply to topic  [ 19 posts ]
Post Help ID this Master Cyl. please!
This brake job has snowballed, and my MC is leaking into the cab down the rod...so I need help replacing this MC. Or figuring out if just one from a vendor will have issues. Need one ASAP as I have a trail ride in a week and I can't afford any more hiccups!
The setup is discs all the way around and I've gotten by fine with the manual brakes.
Sat Nov 25, 2017 11:58 am
Post Re: Help ID this Master Cyl. please!
That looks just like a stock all drum MC.
Sat Nov 25, 2017 7:40 pm
If memory serves, that is correct. But I wanted to confirm. Is that a 1" bore?
Sun Nov 26, 2017 8:26 am
Rock auto says 74 m/c is a 1" bore.
Sun Nov 26, 2017 11:21 am
Good news. Now to see if I can get one sourced in the next couple days...
If I went to a larger bore it would make the pedal harder correct?
Sun Nov 26, 2017 12:23 pm
Sun Nov 26, 2017 12:27 pm
Sun Nov 26, 2017 12:38 pm
Sun Nov 26, 2017 3:31 pm
I just hate to buy something that won't work well. I know I went thru few iterations on my last disc brake conversion before I found one that worked.
Sun Nov 26, 2017 5:30 pm
With no booster you may want to stay with a small piston. Yes a larger one will give you a firmer feel and less travel at the expense of more leg pressure to get stopped.
I thought the 1" bore was very good with disks and no booster. It was perfect on the street and just adequate when in low range going down hill. A bigger bore would require a stronger leg in those conditions. This was with an auto trans though.
Sun Nov 26, 2017 5:34 pm
I decided to try the '79 F-250 Camper special which I can't confirm it's bore size at either 1" or 1-1/16". However, it was a reman and it too was leaking into the footwell past the plunger... So trying another tomorrow...urgh!
Am I doing something wrong to cause this?
I also had them bring in a stock Bronco MC as well as a backup.
Mon Nov 27, 2017 3:59 pm
I don’t know much about this stuff but is the push rod bent maybe pushing it in causing it to ride on one side over the other?
Mon Nov 27, 2017 5:33 pm
I'll look for sure, but it didn't catch my eye.
Mon Nov 27, 2017 6:00 pm
The rod is straight. I just got a bad reman. The replacement came today and I re-installed it and after bench bleeding. It took some extra force to get the rear port to seal than I thought should be necessary, but it finally sealed. I may get some conical copper or alum. washers to seal that connection better.
http://secoseals.com/ or something similar.
I will have to return the Bronco MC and my old one as core.
Tue Nov 28, 2017 5:26 pm
That’s good news. It’d be nice if parts would come to us working. Seems like a tall ask anymore.
Tue Nov 28, 2017 6:46 pm
JD, curious how you like the camper special master on there? Do you like the feel of the pedal?
Sat Jan 06, 2018 2:55 pm
Yeah it seems like a good feel for manual brakes. I've only had the pleasure of one outing but they felt like they did before and I was happy about that.
Sun Jan 07, 2018 5:43 pm
Sun Jan 07, 2018 5:53 pm
To me, it's a good happy medium between firm and soft. I really felt no difference between it and the factory one I had been running.
Mon Jan 08, 2018 8:48 am
32,953,279 Views Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group.
