Rivet nut insert tool
Tools For Sale and Trade
Postby Eck » Wed Jan 03, 2018 6:11 pm
I have 2 7/16 rivet nuts that I need to install but having a hard time tracking down a tool that doesn’t cost me an arm and a leg. Does anyone have a tool that will do that large of a rivet nut I could borrow for 5 minutes?
Re: Rivet nut insert tool
Postby ZOSO » Wed Jan 03, 2018 8:25 pm
make one. A bolt and a nut. Drill the treads out of the nut. slide over the bolt. Screw the bolt into the nut cert. Turn the bolt while holding the nut with a wrench. I've done hundreds like this. No need for a fancy tool.
Postby Eck » Wed Jan 03, 2018 9:41 pm
ZOSO wrote:make one. A bolt and a nut. Drill the treads out of the nut. slide over the bolt. Screw the bolt into the nut cert. Turn the bolt while holding the nut with a wrench. I've done hundreds like this. No need for a fancy tool.
So you hold the nut down to keep the rivnut from coming up with the bolt?
Postby Kinder » Thu Jan 04, 2018 7:45 am
Eck wrote:So you hold the nut down to keep the rivnut from coming up with the bolt?
Essentially yes, it is the “tool” that keeps the rivnut flush against the panel as you tighten it & it expands. I’d add a lock washer that looks like this between the drilled nut & rivnut so the rivnut doesn’t spin as you tighten it.
Postby BroncoCrawler » Thu Jan 04, 2018 8:20 am
I have a tool but not sure I have the die for that size. I think I have 3/8 is the biggest. I have also made a tool like above when the actual tool won't fit in tight spaces.
For sure use a grade 8 bolt and I find that a serated flange nut works great as the base of the tool. The rivnut must not spin as you tighten the bolt. Also put some oil on he bolt threads into the rivnut. I have had them gaul up before and destroyed the nut while trying to crush it.
Alot of companies just send a larger coupler nut (the 1" long nuts) with their products to use as a tool to install their products on jeeps.we get alot of that at the shop. The tool is just faster which is why I bought it.
I'll check when I get to the shop on what dies I have and can take a pic of how I do them with no tool if you want.
Sent from my XT1254 using Tapatalk
BroncoCrawler
Postby Eck » Thu Jan 04, 2018 1:26 pm
Just realized it is 5/16 that I have.
Postby Rox Crusher » Thu Jan 04, 2018 4:03 pm
BroncoCrawler wrote:I have a tool but not sure I have the die for that size. I think I have 3/8 is the biggest. I have also made a tool like above when the actual tool won't fit in tight spaces.
Serrated flange nut.........SPOT ON advice !
Postby BroncoCrawler » Thu Jan 04, 2018 4:05 pm
Well I do have the 5/16 die if you wanna borrow it.
BroncoCrawler
Postby Eck » Thu Jan 04, 2018 6:07 pm
BroncoCrawler wrote:Well I do have the 5/16 die if you wanna borrow it.
I may take you up on that, thank you. I just have two of them to put along my rear cab ledge that will be used to hold down my soft top bracket. Would be very easy to do in your parking lot in probably less than 20 minutes.
Postby BroncoCrawler » Thu Jan 04, 2018 6:28 pm
I'll be around tomorrow and most of the weekend catching up on work.
BroncoCrawler
Return to Shop Tools
