It is currently Fri Nov 22, 2024 11:55 am
[ 9 posts ] |
351W cam sensor, is this a better way?
sykanr0ng
Searching for cam sensors I found this: https://64bittuning.fwscart.com/95__Dec ... 57592.aspxAlready the right height without a spacer. It is all new parts. What do you think?
Tue Jan 30, 2018 10:42 pm |
Re: 351W cam sensor, is this a better way?
It's expensive. that's why no one goes that route. You can buy a spacer and a new sensor for less than $50. I came across another site that had them also but they were over $200. just not worth the cost when you can get the spacer and 4.2l sensor.
Wed Jan 31, 2018 7:48 am |
sykanr0ng
Every thread about a 351W OBD2 has a different cam sensor used.
Which ones work?
Wed Jan 31, 2018 10:02 pm |
Ford 3.8l synchro with a collar and longer oil pump shaft. I’m not sure who is making the collars though anymore. I know that EFI Guy is messing around with his 3D printer and trying to come with a simple and inexpensive solution.
I’ve found the easiest ones to get to in the JY are on a Windstar with the 3.8L.
Wed Jan 31, 2018 11:12 pm |
sykanr0ng
Collars? On CB hankjr was selling them a few years ago, $125 shipped. (One hundred twenty five dollars) http://classicbroncos.com/forums/showth ... p?t=256901Then finding a way to clamp it down? .... And needing to mess with getting a longer oil pump drive shaft? More and more that one I linked to looks like a good idea. Standard hold down, standard oil pump drive shaft. Plug and play.
Thu Feb 01, 2018 2:13 am |
D&D72 on here had run off a bunch of collars at one point. They were 10bucks. I copied Viperwolf1 and milled a hold down groove for the stock clamp. then drilled a few holes for set screws to hold the sensor. Works great. Since I had my engine out doing the oil pump Drive shaft was simple. Just order one for a 351c. It's 1/4" longer just to make sure it is fully seated into the cam sensor.
Thu Feb 01, 2018 8:21 am |
Thu Feb 01, 2018 9:38 am |
sykanr0ng
Thu Feb 01, 2018 3:31 pm |
EFI Guy
The newest design will use the factory hold down. They will be cheap, just not $10 cheap. I need to slowly recoup 3d printer investment funds.
Mon Feb 05, 2018 11:45 pm |
[ 9 posts ] |
Users browsing this forum: Google [Bot] and 17 guests |
