TFB SITREP
Re: Big O
Postby cravenbronco » Fri Feb 02, 2018 7:25 am
Nice
cravenbronco
Re: Big O
Postby TOOLMAN » Fri Feb 02, 2018 7:43 am
That's real nice, Clark.
TOOLMAN
Re: Big O
Postby Jesus_man » Fri Feb 02, 2018 8:50 am
So, where are the promised pictures....?
Re: Big O
Postby Kinder » Fri Feb 02, 2018 5:07 pm
Demanding audience! We still have a lot to do, including bolting the rocker guards back on to cover up the beat on rockers
Re: Big O
Postby Eck » Fri Feb 02, 2018 5:53 pm
Just curious- did you reshoot the whole thing? What was going on with it?
Re: Big O
Postby landshark » Fri Feb 02, 2018 6:43 pm
Let’s see the rear fender handiwork.
Re: Big O
Postby BroncoRaider » Fri Feb 02, 2018 8:18 pm
Greatness.
BroncoRaider
Big O
Postby Kinder » Fri Feb 02, 2018 8:33 pm
Eck wrote:Just curious- did you reshoot the whole thing? What was going on with it?
Kind of, fenders and hood were replaced & Willem wanted the orange stripe removed. He actually wanted to change the color, but I wasn’t willing to front the $, he’s saving up.
Re: Big O
Postby Kinder » Fri Feb 02, 2018 8:34 pm
landshark wrote:Let’s see the rear fender handiwork.
Ha, you’ve noticed my cropping of photos! We want to get a few more updates done and then we’ll do a complete reveal.
Re: Big O
Postby plumbdoctor » Fri Feb 02, 2018 8:42 pm
Enjoy Willem! Thank you both for Your patients....and not dying on you!!
Still a bit to do, but Boulder be ware!!
plumbdoctor
Re: Big O
Postby plumbdoctor » Sat Feb 03, 2018 9:14 am
They gave me ample time ....so we reshot the whole exterior, plus with a couple of changes....the whole thing needed shot
plumbdoctor
Re: Big O
Postby hockeydad4-22 » Wed Feb 07, 2018 8:19 am
Big O looks real nice! W is going to have a lot of fun scooting around the People's Republic.
Re: Big O
Postby Kinder » Sun Apr 08, 2018 2:23 pm
Declan made this console cover for Willem’s bronco, it turned out great.
Re: Big O
Postby Justin » Sun Apr 08, 2018 2:31 pm
Kinder wrote:Declan made this console cover for Willem’s bronco, it turned out great.
That's awesome. If he makes another I'll buy it.
Re: Big O
Postby Kinder » Mon Apr 09, 2018 10:02 am
Justin wrote:That's awesome. If he makes another I'll buy it.
I’ll let him know.
Big O
Postby Kinder » Fri Apr 10, 2020 6:39 pm
Started the ZF swap on TFB, yanked the auto setup out yesterday and started prepping the Bronco for the 3rd pedal. Found a couple of needed bits at the JY today, bolted the ZF adapter onto the D20 and unwrapped the rebuilt ZF. Time to sort out the ill fitting exhaust & fix that leaking oil pan gasket! New parts are so shiny.
Re: Big O
Postby Justin » Fri Apr 10, 2020 8:48 pm
Do you still need a brake pedal? I think I have one.
Re: Big O
Postby Kinder » Sat Apr 11, 2020 6:51 am
Justin wrote:Do you still need a brake pedal? I think I have one.
I do, let me know if you find it.
Re: Big O
Postby Justin » Sat Apr 11, 2020 7:01 am
Free to a good home.Image
Re: Big O
Postby Kinder » Sat Apr 11, 2020 7:52 am
Excellent! Can you set it outside and I’ll work on a time to swing by.
Big O
Postby Kinder » Tue Apr 21, 2020 9:07 am
How do you start an engine w/out a trans bolted up so you can chase down the oil leak coming from the back of the motor? Well, you dig out an old bell housing that you just can’t throw away and bolt up the flex plate and starter and turn the key. Happy to report it isn’t the rear main seal, it was just the oil pan gasket failing again
Re: Big O
Postby Jesus_man » Tue Apr 21, 2020 9:54 am
LOL - that falls under the "You never know when you might need it" category. And so it perpetuates!
Re: Big O
Postby Kinder » Fri May 01, 2020 7:17 am
Happy to report the ZF-5 has been shoehorned in, 1” body lift for the win!
Poke -> Rox
Re: Big O
Postby Strike2 » Fri May 01, 2020 1:31 pm
With a 1" lift that's impressive! Nice job thumbs up
Strike2
Big O
Postby Kinder » Sun Jun 14, 2020 10:07 am
Back on the road today for a quick around the block run. The clutch master barely slipped in between the all other junk bolted to the firewall and inner fender. We’ve temporarily mounted the original shifter to the trans with a small adapter plate, he has plans for something better.
We have a few items to tidy up; clearance the x-member for the front driveshaft, swap hubs over to Warn, improve the new sheet metal for the trans tunnel, install the new twin sticks, etc.
Willem is one step closer to having the Bronco that he always wanted. Welcome to the 3 pedal world my boy!
Re: Big O
Postby Jesus_man » Mon Jun 15, 2020 5:48 am
That's great!! Welcome! Manual tranny's FTW!! LOL!
Re: TFB SITREP
Postby Kinder » Thu Oct 21, 2021 4:28 pm
Willem’s stock Explorer PS pump was starting to fail & I never really like the Explorer reservoir either.
Upgraded to the Viper built PS pump & PSC res w/ 12AN sized supply line, because Justin can’t be the only guy with a big hose, ha!
Re: TFB SITREP
Postby Eck » Thu Oct 21, 2021 5:10 pm
Good upgrade! I have 1 more of the brackets to attach the reservoir to the explorer bracket if you’re interested.
Re: TFB SITREP
Postby Justin » Thu Oct 21, 2021 5:24 pm
How do you like the psc reservoir?
Re: TFB SITREP
Postby Kinder » Fri Oct 22, 2021 5:28 am
Eck wrote:Good upgrade! I have 1 more of the brackets to attach the reservoir to the explorer bracket if you’re interested.
Yes please, I’ll need to look at it closely as Willem’s fiberglass hood has a large support that occupies the space for the factory location.
