TJ's 74 Bronco money pit
Re: TJ's 74 Bronco money pit
Postby Kinder » Fri Dec 15, 2017 4:25 am
Wow, that’s a ton of work, looks great!
Postby Strike2 » Fri Dec 15, 2017 7:15 am
Awesome work, that looks great! thumbs up
Strike2
Postby Jesus_man » Fri Dec 15, 2017 7:38 am
You are cranking that out! I hope you achieve your goal!
The Ammo can armrest - I have been considering that for a while. Do you have the lid hinged or just the original handles? With my new seats, I think I have enough room to do this.
Postby TOOLMAN » Fri Dec 15, 2017 7:44 am
Nice! thumbs up
TOOLMAN
Postby cpldavis37 » Fri Dec 15, 2017 3:42 pm
I bought the hinges, I just haven't installed them yet, but it will be hinged
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Sat Dec 16, 2017 8:42 pm
I got my steering column today in the mail. Only took 2 months to get.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Gunnibronco » Sun Dec 17, 2017 2:09 pm
cpldavis37 wrote:I bought the hinges, I just haven't installed them yet, but it will be hinged
Padded? I keep thinking about whacking my elbow on it. LOL.
Postby cpldavis37 » Sun Dec 17, 2017 2:15 pm
I do want to do a pad, Its just down on the priority list at the moment. I have been installing a ton of new parts and I just haven't gotten to it yet. I think I am going to use memory foam.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Sun Dec 17, 2017 2:18 pm
and I have already whacked my elbow on it.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Viperwolf1 » Mon Dec 18, 2017 8:18 am
Will that memory foam help you remember not to whack your elbow on it?
Postby cpldavis37 » Mon Dec 18, 2017 10:57 am
I hope so. Lol
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Thu Jan 25, 2018 3:24 pm
Its Alive! (3 years after smoking my engine) The motor fired right up and when in high idle runs like a top. Once it gets warm the RPMs go between 600 and 750 and I throw a code. I think my junkyard mass airflow sensor is bad. I still have a ways to go before she will be ready to drive. Thanks to Kirk, Phil and Gary for all the advise and phone support. I would be in bad shape without the great people in this club. Ill post a video once I figure out how to do it.
TJ
F. Scott Fitzgerald
cpldavis37
Postby TOOLMAN » Thu Jan 25, 2018 4:02 pm
thumbs up
TOOLMAN
Postby Kinder » Thu Jan 25, 2018 5:44 pm
Woohoo!
Postby Strike2 » Thu Jan 25, 2018 6:50 pm
Awesome!! thumbs up
Strike2
Postby cpldavis37 » Wed Jan 31, 2018 5:21 pm
Dual Batteries!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Wed Jan 31, 2018 6:31 pm
Are you going to run a fancy controller / isolator or a manual switch?
Postby cpldavis37 » Wed Jan 31, 2018 10:44 pm
I want one of those fancy controllers, but the batteries and cables tapped me this month. It's not going to be fully operational until next month. Only the passenger side is hooked up for now.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Kinder » Thu Feb 01, 2018 6:22 am
There are a lot of dual battery threads on Expedition Portal, I’ve sub’d to a few in hopes of hooking up a dual system with a house battery & solar on the camper in BSD.
Postby ZOSO » Thu Feb 01, 2018 7:16 am
Just my opinion on dual batteries. Just hook em up in parallel. No need for a switch. Isn't the point of having dual batteries to have the capacity all at once? My bronco has had dual batteries since the early 80's and never had a switch in there. When running the winch you want as much of those batteries as possible.
Postby cpldavis37 » Thu Feb 01, 2018 12:00 pm
Yes, but with the controller you get the best of all worlds. It keeps them separate when off and can charge them individually. When you want both you just press a button.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Sun Feb 04, 2018 9:54 pm
Well it runs, but I am having an idle problem. It does fine in high idle (1100-1150 RPM) then it drops to (800-825). When it finally warms up it drops to 625ish and then surges between 450 and 700 before dying out. I am going to change my idle air control valve tomorrow. I cleaned my mass air flow sensor, but that could be the issue. I don't think I have a vacuum leak as I sprayed around the motor with carb cleaner and had no change in idle.
On a side note I put in a 94 explorer radiator with a 3.8 Taurus fan. After running/driving for about 45 min I have been unable to get the temp above 180 and I have yet to turn the fan on high or use my aux pusher. It was only 50 that day, but I am happy so far.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Rox Crusher » Mon Feb 05, 2018 5:58 am
cpldavis37 wrote:Well it runs, but I am having an idle problem. It does fine in high idle (1100-1150 RPM) then it drops to (800-825). When it finally warms up it drops to 625ish and then surges between 450 and 700 before dying out. I am going to change my idle air control valve tomorrow. I cleaned my mass air flow sensor, but that could be the issue. I don't think I have a vacuum leak as I sprayed around the motor with carb cleaner and had no change in idle.
what does the throttle blade fit into throttle body look like ?
sometimes it gets out of adjustment
Postby cpldavis37 » Tue Feb 06, 2018 7:34 pm
I am not sure I understand the question. I have 2 throttle bodies and they both look the same when closed or open. If your talking about the blade under the sensor I have no idea.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Mon Feb 12, 2018 4:47 am
I had to call in the big gun today. Gary came over and hooked up. He adjusted my throttle position sensor and turned up my RPM's to about 850. I started messing with the sensor and made it worse, so a note to everyone else who has idling problems. DON'T TOUCH THE THROTTLE BODY ADJUSTMENT SCREW. (Without Gary) Nothing I tried would have made a difference. Gary you are the man. Runs like a champ!
TJ
F. Scott Fitzgerald
cpldavis37
Postby Rox Crusher » Mon Feb 12, 2018 7:14 pm
cpldavis37 wrote:I am not sure I understand the question. I have 2 throttle bodies and they both look the same when closed or open. If your talking about the blade under the sensor I have no idea.
Sometimes the throttle blade gets out of adjustment and won’t close enough which can cause idling issues.
Postby cpldavis37 » Mon Feb 12, 2018 8:12 pm
As it turns out, with my cam and heads I just needed more idle speed.
TJ
F. Scott Fitzgerald
cpldavis37
Postby cpldavis37 » Wed Feb 27, 2019 1:59 pm
I haven't posted for a while, so here are some pics of my progress. I have been driving and running it for about 1000 miles with only a few hiccups.
TJ
F. Scott Fitzgerald
cpldavis37
Postby Jesus_man » Wed Feb 27, 2019 2:35 pm
Love the dash switches and power points! I would like to do that to mine someday!
Postby Kinder » Wed Feb 27, 2019 3:28 pm
Love the “POLICE INTERCEPTOR” badge, put some red & blue on that thing and roll down the streets of Denver.
