Kinder wrote:I believe the NAPA Auto Parts in Parker will also make up hydraulic lines.
thats what I’m hoping for. I’ll let you know how it goes.Jesus_man wrote:Can they build in a 45* like the other fitting? Perhaps that would avoid a future issue?
ScottBarnes wrote:Napa guys looked at me with crossed eyes and tried to point me to a bearing place downtown Denver. Off to Parker Hose on 46th
well, that would make more sense - but the Napa guys didn’t exactly say it with conviction and didn’t really even lead me to believe they knew what the part was that I was holding [emoji23][emoji31] good to know about Whistler - thx!BroncoCrawler wrote:FYI they probably told you to go to Whistler bearing which has a hydraulic hose division also, it rivals the Parker store. To my knowledge they are the only place in town that can custom make DOT approved brake hoses on the spot. Have used them many times along with hydraquip (formerly emrich & Hill) & the Parker store.
Sent from my XT1254 using Tapatalk
I think that’s where I’m at with this fitting. I spent some quality youtube time over the past couple of days and decided I can make the fitting myself with the right tools. I’ll give it a go - can screw up much with this one since it’s low pressure! Thanks for the encouragement.airbur wrote:Hydraulic lines used to scare me....it was one of those things I had never attempted before.
It's not a big deal. Order hose and fittiings from Summit (a few bandaids from Walgreens if you're doing braided stainless), and you're good to go. Way cheap and you can make perfect custom lengths with whatever fittings you need.
ScottBarnes wrote:I think that’s where I’m at with this fitting. I spent some quality youtube time over the past couple of days and decided I can make the fitting myself with the right tools. I’ll give it a go - can screw up much with this one since it’s low pressure! Thanks for the encouragement.airbur wrote:Hydraulic lines use to scare me....it was one of those things I had never attempted before.
ScottBarnes wrote:I installed a dual return PS pump, and the bend in the low pressure fitting on the gear box is too severe now. I'm sure I can cut off the line with a tubing cutter, but would prefer to get a new line so I've got some sort of "barb" on the end to keep the 3/8" id hose from slipping off. Does anyone know where I can get a new line made locally?
Digger wrote:ScottBarnes wrote:I installed a dual return PS pump, and the bend in the low pressure fitting on the gear box is too severe now. I'm sure I can cut off the line with a tubing cutter, but would prefer to get a new line so I've got some sort of "barb" on the end to keep the 3/8" id hose from slipping off. Does anyone know where I can get a new line made locally?
Hey Scott - Is that a 45° flare fitting or O-ring fitting going into the box?
I have a tubing flaring kit, but my FIL is borrowing it right now. I could help you with fabbing a new line or modding the old one depending on your timeline.
Protruck15 wrote:Hey Scott,
If you need I think i have an extra AN adapter for the steering box if you need. I am almost ready to make new lines for mine also a dual line power steering pump and i have a spare that i am bring to baja.
Let me know if need.
Mike
Protruck15 wrote:Scott,
I think this is the part number
AEROQUIP FBM2964 AN-6 ADAPTER
o 3/8 Male Inverted Flare to AN-6 Male Adapter
o S.A.E. 37 / 45 Flare (JIC/AN) 5/8-18 thread
o For use with Aeroquip TFE AN-6 Spec Hose
o Silver Zinc Dichromate Finish Mild Steel
o Fits most 1979 and older Saginaw P Series Pumps with
3/8 flare female output / Saginaw Box Low Pressure Return
This is from the Hydratech
I think i have an extra one i can look tonight if you need it?
You can also get them at summit, jegs or amazon.
Mike
